Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 15015:2007 Precast concrete products - Bridge elements
10-24-2010, 05:21 AM
This European Standard applies to precast concrete structural elements produced in a factory and used in bridge construction, for example deck elements, abutments, elements for piers and precast arches.
Normal weight concrete elements are considered, both reinforced and prestressed; their use can be on road bridges, railway bridges and footbridges.
Deck elements include both single elements from which the deck may be composed (beams, slabs, ribbed or cellular elements) and elements consisting of a segment of the entire deck.
The elements for abutments are precast elements able to support vertical and horizontal actions applied by the deck and the earth pressure due to the filling material.
The pier elements can consist of a segment of the pier or, for small heights, the entire pier.
Some examples of elements dealt with are shown in Annex A.
The durability aspects are also considered.
This European Standard makes reference to precast elements produced in a factory or near the construction site in a place protected from adverse weather conditions. It is assumed that if the elements are not manufactured in a factory, the production conditions assure the same level of quality control as in a factory. It is assumed that the production place is protected from rain, sunshine and wind.
Some of the elements are also treated in other European Standards (e.g. beams, slabs). This European Standard deals with the specific aspects related to the use of these elements in bridge construction.
Foundation piles, barriers, bumpers, guards and box culverts are out the scope of this European Standard.
  • kowheng, Pinkto, toa011, Grunf, we_mbm, Dell_Brett, cve_jule, chenamoy, roaming79, ruaumoko, madzaz, ilgar, jocagalhao, kmmh76, pm81
  EN 13791:2007 Assessment of in-situ compressive strength in structures and precast co ir_71 4 5,409 02-15-2022, 06:23 AM
Last Post: CAMSECT
  EN 13501 Fire classification of construction products and building elements. ir_71 2 3,170 10-22-2018, 08:12 AM
  EN 13369:2004 (Common rules for precast concrete products) raffah 2 3,334 03-07-2018, 01:53 PM
  EN 12843:2004 Precast concrete products - Masts and poles ir_71 3 3,566 01-24-2015, 01:19 AM
Last Post: concreteok
  EN 14992:2007 Precast concrete products - Wall elements ir_71 1 2,668 01-20-2014, 03:27 PM
Last Post: milova
  EN 12794:2005 Precast concrete products - Foundation piles ir_71 1 2,614 04-11-2013, 01:59 AM
Last Post: st77bel
  EN 15037 Precast Concrete Products. Beam-and-block floor systems ir_71 0 2,112 12-14-2010, 04:02 AM
