Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 12794:2005 Precast concrete products - Foundation piles
10-24-2010, 05:26 AM
This document specifies the terminology, requirements, basic performance criteria, test methods and evaluation of conformity that will be applied to precast concrete foundation piles, factory produced for building and civil engineering works and installed at the site by the use of impact, vibration, pressing or other suitable techniques. This document may also be applied to products manufactured in temporary plants on site where production is controlled in accordance with the provisions of Clause 6 and is protected against adverse weather conditions as necessary.
This document applies to foundation piles produced in a plant as reinforced or prestressed concrete elements. The cross-section may be solid or provided with a hollow core, either prismatic or cylindrical. The cross-section may be constant over the full length or tapered partly or wholly along the pile or pile segment length.
This document deals with foundation piles manufactured either in one length or in segments with cast-in pile joints. The foundation piles may have an enlarged toe or a pile shoe.
This document applies to normal weight concrete as defined in EN 206-1 compacted so as to retain no appreciable amount of entrapped air other than entrained air.
  • kowheng, Pinkto, Trishu999, blaze, avscorreia, toa011, Grunf, we_mbm, isurya, Dell_Brett, cve_jule, chenamoy, roaming79, cappotchi, ilgar, vvvv
 st77bel
Romania
User ID: 12964
Threads: 16
Likes: 432 in 86 posts
Given Likes: 696
04-11-2013, 01:59 AM
BS EN 12794:2005 here
Password:
[-] The following 9 users Like st77bel's post:9 users Like st77bel's post
  • viet2010, utan, Filko, Andrew seah, hapsea, Dell_Brett, Jackass, peixoto, mahyarov
  EN 13369:2004 (Common rules for precast concrete products) raffah 2 3,317 03-07-2018, 01:53 PM
  EN 12843:2004 Precast concrete products - Masts and poles ir_71 3 3,536 01-24-2015, 01:19 AM
Last Post: concreteok
  EN 14992:2007 Precast concrete products - Wall elements ir_71 1 2,652 01-20-2014, 03:27 PM
Last Post: milova
  EN 14487-1:2005 Sprayed concrete - Part 1: Definitions, specifications and conformity datagap 0 2,027 01-17-2011, 08:39 PM
Last Post: datagap
  EN 15037 Precast Concrete Products. Beam-and-block floor systems ir_71 0 2,103 12-14-2010, 04:02 AM
  EN 1001:2005 Durability of wood and wood-based products. Terminology. ir_71 0 1,811 12-02-2010, 06:18 PM
  EN 14843:2007 Precast concrete products - Stairs ir_71 2 2,959 10-29-2010, 04:55 PM
