Modeling of Masonry Infill Panels for Structural Analysis
A Madan, A M Reinhorn, J B Mander, R E Valles
JOURNAL OF STRUCTURAL ENGINEERING (1997)
Volume: 123, Issue: 10, Pages: 1295-1302
Abstract:
An analytical macromodel based on an equivalent strut approach integrated with a smooth hysteretic model is proposed for representing masonry infill panels in nonlinear analysis of frame structures. The hysteresis model uses degrading control parameters for stiffness and strength degradation and slip "pinching" that can be implemented to replicate a wide range of hysteretic force-displacement behavior resulting from different design and geometry. The paper presents the development of the hysteretic model and the definitions of the control parameters, which can be determined using any suitable theoretical model for masonry infills. An available theoretical model for simplified engineering evaluation of masonry infilled frames was explored for estimating the control parameters of the proposed macromodel. The macromodel was incorporated in a nonlinear structural analysis program, IDARC2D Version 4.0, for quasi-static cyclic and dynamic analysis of masonry infilled frames. Simulations of experimental force-deformation behavior of prototype infill frame subassemblies are performed to validate the proposed model. A lightly reinforced concrete frame structure is analyzed for strong ground motions to evaluate the influence of masonry infill panels on the dynamic response.
[-] The following 7 users say Thank You to aslam for this post:
  • ptcruiser, ptcruiser, orambo, orambo, KAMM, KAMM, Grunf
Use all Software's or Books shared in our Forum for EVALUATION Purpose,If you like to use these materials for Commercial Purpose ,It is Strictly suggested to Buy for Supporting the Developers.
[-] The following 8 users say Thank You to kvtasp for this post:
  • 3fan, kowheng, malc, slowet, Jackass, sructme, Hengki, learner20
Effect of modeling range on structural analysis for powerhouse of hydroelectric power arshiakh 0 1,203 01-20-2014, 08:53 AM
Last Post: arshiakh
Implications of vertical mass modeling errors on 2D dynamic structural analysis asim99 0 1,183 12-29-2012, 01:16 AM
Last Post: asim99
