Civil Engineering Association eBooks Journals, Papers and Presentations Small-Scale Modeling of Reinforced Concrete Structural Elements for Use
 DamirDz
User ID: 5785
Threads: 47
Likes: 393 in 111 posts
Given Likes: 626
11-17-2012, 01:22 PM (This post was last modified: 11-17-2012, 01:29 PM by mybest.)
Small-Scale Modeling of Reinforced Concrete Structural Elements for Use in a Geotechnical Centrifuge
Author: Knappett, J., Reid, C., Kinmond, S., and O’Reilly, K. | Size: ?? MB | Format: PDF | Quality: Unspecified | Publisher: Journal of Structural Engineering | Year: 2011 | pages: 9
This paper discusses the modeling of reinforced concrete structural elements for use in geotechnical centrifuge modeling of soil-structure interaction problems. Centrifuges are employed in geotechnical modeling so that the nonlinear constitutive behavior of soil in small-scale models can be correctly modeled at prototype scale. Such models typically necessitate large scale factors of between 1∶20 and 1∶100, which is significantly larger than most conventional small-scale structural modeling. A new model concrete has been developed consisting of plaster, water, and fine sand as a geometrically scaled coarse aggregate that can produce a range of model concretes with cube compressive strengths between 25–80 MPa. Reinforcement is modeled using roughened steel wire (beams) or wire mesh (slabs). To illustrate the validity of the modeling technique, a series of three- and four-point bending tests were conducted on model beams designed to represent a 0.5×0.5  m square section prototype beam at 1∶40 scale, and model slabs designed to represent a prototype slab with plan dimensions of 4.8×4.8  m and 0.4 m deep (also at 1∶40 scale). The amount of longitudinal reinforcement was varied and tests both with and without shear reinforcement were conducted. The models were able to accurately reproduce both shear and flexural (bending) failures when loaded transversely. The load capacity (strength), bending stiffness, and ductility were shown to be simultaneously and appropriately scaled over a range of scaling factors appropriate for geotechnical centrifuge testing, and the technique therefore provides a significant improvement in the ability to accurately model soil-structure interaction behavior in centrifuge models.
Vol. 137, No. 11, November 2011, pp. 1263-1271
[-] The following 1 user Likes DamirDz's post:1 user Likes DamirDz's post
  • Grunf
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
11-17-2012, 01:28 PM
Here
[-] The following 9 users Like mybest's post:9 users Like mybest's post
  • Dell_Brett, kowheng, blaze, mary, zrilek, cace-01, ykhackhack, DamirDz, Grunf
  Phd thesis: Chemical Prestressing of Thin Concrete Elements with Carbon Textile Rei poolmand 0 4,224 11-22-2021, 05:12 AM
  SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 4,559 04-03-2014, 12:26 PM
  Use Of Steel Fiber Reinforced Concrete In Structural Members With Highly Complex Stre aslam 1 4,932 04-08-2013, 08:00 AM
  Soft capacitive sensor for structural health monitoring of large-scale systems amritarao 0 3,628 02-24-2013, 06:30 AM
Last Post: amritarao
  Seismic Bracing of Non-Structural Elements asim99 0 3,439 02-03-2013, 09:39 PM
Last Post: asim99
  Large scale structural optimization lisine 0 3,431 11-07-2012, 08:05 AM
  Structural Retrofitting of Reinforced Concrete Beams using carbon fibre reinf.polymer cordoba123 0 4,520 10-09-2012, 08:57 PM
Last Post: cordoba123
