Civil Engineering Association eBooks Journals, Papers and Presentations Use Of Steel Fiber Reinforced Concrete In Structural Members With Highly Complex Stre
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
Points:42,050 EP
06-19-2012, 04:32 AM
Use Of Steel Fiber Reinforced Concrete In Structural Members With Highly Complex Stress Fields
Author: Pareek, Tarun | Size: 127 MB | Format: PDF | Quality: Unspecified | Publisher: THE UNIVERSITY OF TEXAS AT ARLINGTON (THESIS) | Year: 2012 | pages: 316 | ISBN: -
Reinforced concrete (RC) members with significant geometric discontinuities and complex stress distributions under loading require considerable analyses and usually complicated reinforcement detailing. RC members with large openings are one of the examples. These large openings may interrupt the load transfer by direct concrete struts and cause substantial decrease in strength and unpredictable failure modes. The reinforcement detailing of these concrete members based on strut-and-tie models (STMs) is generally complicated and very often, these models cannot predict the failure mechanism due to localized damages. The actual stress fields in such members are typically very different from that predicated by STMs, as evidenced by many experimental investigations. This study investigates the influence of highly complex stresses on the mechanical behavior of deep beams. One RC and three steel fiber reinforced concrete (SFRC) deep beams with two large openings were monotonically loaded up to failure. A simple design approach based on elastic finite element analysis (FEA) was also proposed for the reinforcement detailing of the SFRC specimens. Experimental results indicated that, although the complex reinforcement detailing as per STM was not used, the SFRC specimens with 1.5% and 1% volume fraction of steel fibers reached much higher strength than the design load and exhibited ductile mode of failure.
[-] The following 10 users Like aslam's post:10 users Like aslam's post
  • david-smith, kowheng, blaze, malc, cace-01, jcbv, simanta, cordoba123, zrilek, Dell_Brett
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
Points:29,008 EP
04-08-2013, 08:00 AM
another link of 11.9MB OCR
password:
  • kowheng, blaze, lisine, isurya, jcbv, Jackass
  BEHAVIOR OF FIBER-REINFORCED POLYMER (FRP) COMPOSITE PILES UNDER VERTICAL LOADS ir_71 1 6,227 06-01-2015, 05:11 PM
  BEHAVIOUR OF STEEL SINGLE ANGLE COMPRESSION MEMBERS AXIALLY LOADED THROUGH ONE LEG asim99 1 4,649 10-15-2014, 11:00 PM
Last Post: KhaLed-S.E
  Design of Cold Formed Steel Unequel Angle Compression Members darkdkay 2 6,431 10-15-2014, 10:51 PM
  SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 4,274 04-03-2014, 12:26 PM
  A high performance fibre reinforced cement based plaster for retrofitting RC members asim99 0 4,016 05-11-2013, 05:57 PM
Last Post: asim99
  Residential Hip Roof Framing Using Cold-Formed Steel Members ir_71 1 5,364 04-08-2013, 05:58 AM
  Small-Scale Modeling of Reinforced Concrete Structural Elements for Use DamirDz 1 4,785 11-17-2012, 01:28 PM
Last Post: mybest
