Design of Cold Formed Steel Unequel Angle Compression Members
Author: Ben Young, Ehab Ellobody | Size: 640 KB | Format: PDF | pages: 8 (330-338)
[Image: 38879618558697331554.png]
Presents nonlinear finite element analysis of cold-formed steel unequal angles and comparison of the results obtained with the experimental tests.
Learn Until You DIE...
[-] The following 8 users say Thank You to darkdkay for this post:
  • usman, ISTRAKTURA, blaze, jcbv, nuttapolk, Dell_Brett, oanm2000, kowheng
Uploaded: Jan/08/2011, File Size: 580.51 KB, RAR'd single PDF (paginated, bookmarked, searchable text)
[-] The following 3 users say Thank You to Grunf for this post:
  • usman, oanm2000, kowheng
links are dead
can you uploaded it again
thanks in Advance :)
"Run after what you want while you can. Today's the youngest day of your life."
Buckling of built-up compression members in the plane of the connectors asim99 2 2,101 12-12-2014, 05:39 PM
Last Post: Veggeta
BEHAVIOUR OF STEEL SINGLE ANGLE COMPRESSION MEMBERS AXIALLY LOADED THROUGH ONE LEG asim99 1 1,623 10-16-2014, 12:00 AM
Last Post: KhaLed-S.E
SCI P129: Building Design using Cold Formed Steel Sections: Fire Protection ir_71 2 2,475 12-18-2013, 09:42 AM
Last Post: bigone
Review of drilled shaft foundation design of high angle electrical transmission strc. jacs1976 0 1,173 10-07-2013, 05:28 PM
Last Post: jacs1976
Dynamic Testing of Single- and Double-Story Steel-Sheathed Cold-Formed Steel-Framed S asim99 0 1,262 05-09-2013, 05:35 AM
Last Post: asim99
