Soft capacitive sensor for structural health monitoring of large-scale systems
Current time: 01-23-2018, 06:40 PM
Author: amritarao
Last Post: amritarao
Replies 0
Views 1002
Author: S. Laflamme | Size: 1.5 MB | Format: PDF | Quality: Original preprint | Publisher: wiley | Year: 2010 | pages: 11
Structural integrity of infrastructures can be preserved if damage is diagnosed, localized, and repaired in
time. During the past decade, there has been a considerable effort to automate the process of structural
health monitoring, which is complicated by the inherent large size of civil structures. Hence, a need has
arisen to develop new approaches that enable more effective health monitoring.
In this paper, a new sensing technique for damage localization on large civil structures is proposed.
Specifically, changes in strain are detected using a capacitance sensor built with a soft, stretchable dielectric
polymer with attached stretchable metal film electrodes. A change in strain causes a measurable change in
the capacitance of the sensor, which can be directly monitored when the sensor is fixed to a structure.
The proposed method is shown here to permit an accurate detection of cracks. The proposed system
deploys a layer of dielectric polymer on the surface of a structural element, and regularly monitors any
change in capacitance, giving in turn information about the structural state. The smart material is
composed of inexpensive silicone elastomers, which make the monitoring system a promising application
for large surfaces. Results from tests conducted on small-scale specimens showed that the technology is
capable of detecting cracks, and tests conducted on large-size specimens demonstrated that several sensor
patches organized on a sensor sheet are capable of localizing a crack. The sensor strain also exhibits a high
correlation with the loss of stiffness
[-] The following 6 users say Thank You to amritarao for this post:
  • blaze, tluc, kowheng, Dell_Brett, cace-01, ting tsai huang
Computation of Wind Flow around a Tall Building and the Large--Scale Vortex Structure asim99 0 1,173 12-31-2012, 03:09 AM
Last Post: asim99
Seismic Isolation Retrofit of a Medical Complex by Integrating Two Large-Scale Buildi ssobhan 0 1,171 11-30-2012, 10:58 AM
Last Post: ssobhan
Small-Scale Modeling of Reinforced Concrete Structural Elements for Use DamirDz 1 1,419 11-17-2012, 02:28 PM
Last Post: mybest
Large scale structural optimization lisine 0 889 11-07-2012, 09:05 AM
Full Scale Cyclic Deflection Testing of Foundation Systems for Highway Brigdes II faros3000 1 1,399 06-24-2012, 05:23 PM
Last Post: 3fan
