Civil Engineering Association eBooks Journals, Papers and Presentations An equivalent frame model for seismic analysis of masonry and reinforced concrete bui
 Veggeta
Guatemala
User ID: 114
Threads: 103
Likes: 4,273 in 520 posts
Given Likes: 402
03-31-2011, 05:51 PM (This post was last modified: 03-31-2011, 06:38 PM by Grunf.)
An equivalent frame model for seismic analysis of masonry and reinforced concrete buildings
Interesting paper....
Y. Belmouden , P. Lestuzzi
December 2007
Rar File 0.80 MB
14 Pabes
Abstract
In this paper a novel equivalent planar-frame model with openings is presented. The model deals with seismic analysis using the Pushover method for masonry and reinforced concrete buildings. Each wall with opening can be decomposed into parallel structural walls made of an assemblage of piers and a portion of spandrels. As formulated, the structural model undergoes inelastic flexural as well as inelastic shear deformations. The mathematical model is based on the smeared cracks and distributed plasticity approach. Both zero moment location shifting in piers and spandrels can be evaluated. The constitutive laws are modeled as bilinear curves in flexure and in shear. A biaxial interaction rule for both axial force–bending moment and axial force–shear force are considered. The model can support any shape of failure criteria. An event-to-event strategy is used to solve the nonlinear problem. Two applications are used to show the
ability of the model to study both reinforced concrete and unreinforced masonry structures. Relevant findings are compared to analytical results from experimental, simplified models and finite element models such as Drain3DX and ETABS finite element package.
[Image: 67243038861313679170.jpg]
[Image: 10206360813587663377.jpg]
[-] The following 13 users Like Veggeta's post:13 users Like Veggeta's post
  • kowheng, Dell_Brett, Mouh@ndiss, seriousboy, malc, jcoronellr, melkat, Adam Smith, pingfan2, miquan, zrilek, ISTRAKTURA, TAFATNEB
  Experiment and Analysis on X-Shaped Reinforced Concrete Joint in Diagrid Structures asim99 1 6,113 04-20-2018, 05:19 PM
Last Post: munycamsec
  Seismic Retrofitting of Historic Masonry Buildings – Case Study Grunf 3 10,267 05-26-2016, 03:19 AM
Last Post: gulilero
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 8,740 02-10-2016, 02:49 PM
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 5,821 12-26-2014, 09:49 PM
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 5,990 11-15-2014, 02:07 PM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,054 10-08-2014, 02:06 PM
  Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 4,954 09-05-2014, 02:03 PM
