STAAD.Pro V8i SELECTseries 5, build 20.07.10.64
STAAD.Pro V8i SELECTseries 5, build 20.07.10.64 enhancements:
AISC 360-10 Steel Design Performance Boost
The current AISC 360-10 steel design module in STAAD.Pro has been turbo charged by restructuring the design processes to use multi-threading which can deliver a major performance boost that results in designs being performed quicker and making designers more productive.
Canadian Concrete Design in Concrete Mode
A new beam and column design module, to the Canadian concrete design standard, has been added to the Concrete Mode giving designers a clear design with detailed supporting calculations.
SP 16.13330.2011 Steel Design
A new steel design module has been added to the main analysis and design engine to the current Russian steel design specification.
SP 20.13330.2011 Wind Loading
An additional new wind load pre-processing module has been added that can quickly create wind loading on frames to the current Russian specification.
SP 14.13330.2011 Seismic Loading
A new response spectra routine has been added to support the seismic definitions as defined in the current Russian design code.
User Reports
The popular method to create custom user reports has been updated so that it is now possible to include more detail of the analysis functions that have been introduced into STAAD.Pro over recent times such as Reference and Notional load cases.
Finite element Analysis
Improved analysis routines for models incorporating quad-plates means that the analysis can now be performed on models with slightly warped elements which previously would have not been possible.
Cloud Analysis
An updated UI improves project interoperability with Bentley CONNECT Scenario Services giving the opportunity to explore the effects of alternative scenarios and determine a best solution for given criteria.
Over 180 documented updates are listed in the Revision History document (view details here) with over 90 updates specifically in the analysis and design engine ranging from small enhancements in the output to corrections affecting a number of the design routines.
[Image: homepage.png]
Copying links form other forums is nice but better to give a solution and not only to run posting and write Crack/Keygen none
[Image: 18216202911026426607.gif]
Use the attachment and read the text
.rar   Bentley.liclib.rar (Size: 348.05 KB / Downloads: 774)
TORRENT Bentley STAAD Pro V8i (SELECTSeries5) 20.07.10.65
STAAD.Pro is the structural engineering professional’s choice for steel, concrete, timber, aluminum, and cold-formed steel design of virtually any structure including culverts, petrochemical plants, tunnels, bridges, piles, and much more through its flexible modeling environment, advanced features, and fluent data collaboration.
STAAD.Pro allows structural engineers to analyze and design virtually any type of structure through its flexible modeling environment, advanced features and fluent data collaboration.
Flexible modeling is provided by a state-of-the-art graphical environment and the design supports over 70 international codes and over 20 U.S. codes in 7 languages.
An array of advanced structural analysis and design features are included such as nuclear
[-] The following 12 users say Thank You to TAFATNEB for this post:
  • oanm2000, zrilek, Dell_Brett, amindoxiti, PinkPant, Rainbow, chenamoy, nibbi, bigone, kneth, rhino13, taifur
Bentley STAAD.Pro V8i (SELECTSeries 5) 20.07.10.66
[Image: 01468732360376035043.jpeg]
entley Systems Incorporated, the leading company dedicated to providing comprehensive software solutions for sustaining infrastructure, has released an update to STAAD.Pro V8i (SELECTSeries 5) 20.07.10.66, is the structural engineering professional’s choice for steel, concrete, timber, aluminum, and cold-formed steel design of virtually any structure including culverts, petrochemical plants, tunnels, bridges, piles, and much more through its flexible modeling environment, advanced features, and fluent data collaboration.
- Flexible modeling is provided by a state-of-the-art graphical environment and the design supports over 70 international codes and over 20 U.S. codes in 7 languages.
- An array of advanced structural analysis and design features are included such as nuclear certification for 10CFR Part 50, 10CFR 21, ASME NQA-1-2000, time history and push over analysis and cable (linear and non-linear) analysis.
Efficiencies are gained through the ability to maintain and streamline current workflows with fluent data collaboration. STAAD.Pro integrates with other Bentley products such as STAAD.foundation and ProSteel and OpenSTAAD is provided for integration with third party programs.
[-] The following 17 users say Thank You to TAFATNEB for this post:
  • jcbv, Dell_Brett, cace-01, blaze, oanm2000, seriousboy, zrilek, learner20, malee, PinkPant, er.shyams, warlord1, bao2004, nibbi, promo8, bridgeengineer, MOSS2000
[-] The following 14 users say Thank You to emmi for this post:
  • PinkPant, learner20, cace-01, vvvv, TAFATNEB, oanm2000, malc, Dell_Brett, jcbv, bigone, amindoxiti, ting tsai huang, tang1942, Andrew seah
Additional comment for crack:
It is need to copy Bentley.liclib.dll to folder C:\SProV8i SS5\STAAD\RCDesigner too.
[-] The following 9 users say Thank You to ajra for this post:
  • PinkPant, thanzawtun, jcbv, bigone, zrilek, oanm2000, ting tsai huang, Andrew seah, bridgeengineer
(03-04-2015, 09:41 AM)emmi Wrote:
crack included
Nice post. Is it possible you include the crack with .dll separately? It would help with those who have the plain build 10.66 software without the crack file; minimize bandwidth usage. Thank you.
please reload links! thank you!
Bentley STAAD.Pro V8i (SELECTSeries 6) 20.07.11.70 RajaK 4 8,721 06-08-2017, 11:29 AM
Last Post: bigone
Bentley STAAD.Pro V8i (SELECTSeries 6) 20.07.11.33 er.shyams 6 8,002 01-15-2016, 09:39 AM
Last Post: RajaK
Bentley STAAD Pro V8i (SELECTSeries 4) 20.07.09.31(Windows 7, 8 x64) rony_shawkat 2 4,863 11-10-2014, 04:31 AM
Last Post: aslam
Bentley Staad Pro v8 (SELECTseries 4) 20.07.09.31 (15 days trial) BennyP 4 8,771 09-09-2013, 06:23 AM
Last Post: pezhmankhan
Bentley Staad(X)v8i Tower (SelectSeries 3) v08.02.03.12 Arigato 0 4,441 02-17-2013, 12:12 PM
Last Post: Arigato
