Bentley Staad Pro v8 (SELECTseries 4) 20.07.09.31 (15 days trial)
Current time: 09-19-2018, 11:33 AM
Author: BennyP
Last Post: pezhmankhan
Replies 4
Views 8625
[Image: 40939378652672708495.gif]
STAAD.Pro is a general purpose structural analysis and design program with applications primarily in the building industry - commercial buildings, bridges and highway structures, industrial structures, chemical plant structures, dams, retaining walls, turbine foundations, culverts and other embedded structures, etc. The program hence consists of the following facilities to enable this task.
Graphical model generation utilities as well as text editor based commands for creating the mathematical model. Beam and column members are represented using lines. Walls, slabs and panel type entities are represented using triangular and quadrilateral finite elements. Solid blocks are represented using brick elements. These utilities allow you to create the geometry, assign properties, orient cross sections as desired, assign materials like steel, concrete, timber, aluminum, specify supports, apply loads explicitly as well as have the program generate loads, design parameters etc.
Analysis engines for performing linear elastic and pdelta analysis, finite element analysis, frequency extraction, and dynamic response (spectrum, time history, steady state, etc.).
Design engines for code checking and optimization of steel, aluminum and timber members. Reinforcement calculations for concrete beams, columns, slabs and shear walls. Design of shear and moment connections for steel members.
Result viewing, result verification and report generation tools for examining displacement diagrams, bending moment and shear force diagrams, beam, plate and solid stress contours, etc.
Peripheral tools for activities like import and export of data from and to other widely accepted formats, links with other popular softwares for niche areas like reinforced and prestressed concrete slab design, footing design, steel connection design, etc.
A library of exposed functions called OpenSTAAD which allows you to access STAAD.Pro’s internal functions and routines as well as its graphical commands to tap into STAAD’s database and link input and output data to third-party software written using languages like C, C++, VB, VBA, FORTRAN, Java, Delphi, etc. Thus, OpenSTAAD can be used to link in-house or third-party applications with STAAD.Pro.
Includes Staad Foundation 05.03.00.32
No limits to creativity
[-] The following 26 users say Thank You to joker™ for this post:
  • Rainbow, karthikeyans3d, cace-01, Dell_Brett, malc, mahyarov, verongskey, Andrew seah, taifur, Limpias72, psppsp, araza023, eliseo.as, zrilek, devilmaycry, vvvv, piyush86, grgr, lednar_ved, urdanetanp, bigone, awgawhtoo80, jaks, mibaksh, julioreptil, harsono
Staad Pro V8i ( Select Series 4 ) 20.07.09.31
[Image: 31916663129946946066.jpg]
New Crack. SteadyState Analysis in Staad is working.
Some Other Bentley Products can be activated with this patch. See the Image
a- Follow the Forum Rules.
[-] The following 28 users say Thank You to asim99 for this post:
  • pezhmankhan, alilo, verongskey, malc, ykhackhack, joker™, Dell_Brett, araza023, ASEC, zrilek, ssobhan, Williams, wksaw73, taifur, Rainbow, bigone, Andrew seah, varmap, wanwin, subin91, ranger, Diquan, nibbi, terrorruban, jaks, narendra, mibaksh, julioreptil
Mirror for New Medicine (Post #4)
[-] The following 12 users say Thank You to pezhmankhan for this post:
  • alilo, Rainbow, zrilek, Williams, eliseo.as, taifur, bigone, varmap, subin91, jacky899, nickycruz, julioreptil
Bentley.STAAD.PlanWin.V8i.v14.0.5 kirankumarklk 0 764 05-08-2018, 01:30 PM
Last Post: kirankumarklk
Bentley STAAD.Pro CONNECT Edition 21.00.00.57 (x64) BennyP 1 2,005 12-30-2017, 05:52 PM
Last Post: reagan_liu
Bentley STAAD.Pro V8i (SELECTSeries 6) 20.07.11.70 RajaK 4 8,365 06-08-2017, 11:29 AM
Last Post: bigone
Bentley AECOsim Building Designer V8i (SELECTSeries 3) 08.11.09.376 BennyP 1 3,464 05-15-2017, 09:12 AM
Last Post: wisamnn
Bentley SewerGEMS V8i (SELECTSeries 4) 08.11.04.54 emmi 2 3,616 12-23-2016, 05:29 AM
Last Post: balimela
