Bentley STAAD Pro V8i (SELECTSeries 4) 20.07.09.31(Windows 7, 8 x64)
[Image: 39216473383023534306.jpg]
STAAD.Pro is the structural engineering professional’s choice for steel, concrete, timber, aluminum, and cold-formed steel design of virtually any structure including culverts, petrochemical plants, tunnels, bridges, piles, and much more through its flexible modeling environment, advanced features, and fluent data collaboration.
[-] The following 16 users say Thank You to rony_shawkat for this post:
  • oanm2000, PinkPant, vvvv, TAFATNEB, bridgeengineer, zrilek, karthikeyans3d, harsono, Munykong, chenamoy, bigone, Dell_Brett, Andrew seah, Rainbow, deltalead, Rami11
STAAD.Pro V8i
(Version: 20.07.10.65 Date: 11/3/2014 FileSize: 440.6 MB)
.rar   Bentley.STAAD.Pro.V8i.SS5.v20.07.10.65.rar (Size: 609.89 KB / Downloads: 324)
[-] The following 20 users say Thank You to bigone for this post:
  • learner20, zrilek, malee, oanm2000, melekeen, cace-01, kneth, malc, Albert, Dell_Brett, dl4all, raja, karthikeyans3d, rony_shawkat, rezaismaniar, Rainbow, Rami11, narendra, sandeepth, lasalleguy
STAAD.Pro V8i (Version: 20.07.10.65) Enhancements:
The Revision History document included in the ReadMe outlines all the issues that have been addressed which can be summarized as:-
Russian Steel Design
Correct variable initialisation to support multiple member design
Improved pagination
Design results available in the GUI
Russian Wind Design
Correction for use with the Basic solver
Canadian Steel Design S-16-01
Class 4, slender section effective areas for angle profiles
AISC 360-10/05
Compression capacity and torsion capacity for circular hollow sections
Double angle section design
Designs governed by slenderness
IS 1893
Command processing updates
Advanced Cable Analysis
Vertical cable analysis
Concrete Mode
Support for changing member dimensions after an initial design
Connection Mode
Support of double angle sections for bracing
[-] The following 7 users say Thank You to aslam for this post:
  • bigone, learner20, TAFATNEB, raja, oanm2000, Rainbow, Dell_Brett
Bentley STAAD.Pro CONNECT Edition V22 (22.00.00.015)+RCDC+Building Planner kirankumarklk 0 592 01-17-2019, 10:04 AM
Last Post: kirankumarklk
Bentley.STAAD.PlanWin.V8i.v14.0.5 kirankumarklk 0 936 05-08-2018, 01:30 PM
Bentley STAAD.Pro CONNECT Edition 21.00.00.57 (x64) BennyP 1 2,295 12-30-2017, 05:52 PM
Last Post: reagan_liu
Bentley STAAD.Pro V8i (SELECTSeries 6) 20.07.11.70 RajaK 4 8,787 06-08-2017, 11:29 AM
Last Post: bigone
Bentley AECOsim Building Designer V8i (SELECTSeries 3) 08.11.09.376 BennyP 1 3,651 05-15-2017, 09:12 AM
Last Post: wisamnn
