Civil Engineering Association eBooks Journals, Papers and Presentations Seismic Induced Global Collapse of Non-deteriorating Frame Structures
04-26-2014, 11:08 AM
Author: Christoph Adam and Clemens J ̈ ager | Size: 784 KB | Format: PDF | Quality: Unspecified | Publisher: University of Innsbruck, Department of Civil Engineering Sciences, 6020 Innsbruck, Austria | pages: 20
[Image: 85990111792570400210.jpg]
Abstract In a severe seismic event the destabilizing effect of gravity loads, i.e. the P-delta effect, may be the primary trigger for global collapse of quite flexible structures exhibiting large inelastic deformations. This article deals with seismic
induced global collapse of multi-story frame structures with non-deteriorating material properties, which are vulnerable to the P-delta effect. In particular, the excitation intensity for P-delta induced structural collapse, which is referred to as collapse capacity, is evaluated. The initial assessment of the structural vulnerability to P-delta effects is based on pushover analyses. More detailed information about the collapse capacity renders Incremental Dynamic Analyses involving a set of recorded ground motions. In a simplified approach equivalent single-degree-of-freedom systems and collapse capacity spectra are utilized to predict the seismic collapse capacity of regular multi-story frame structures.
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
04-30-2014, 05:40 PM
Get it here;
[-] The following 12 users Like ssobhan's post:12 users Like ssobhan's post
  • blaze, vardan, Mohammad6299, jcbv, oanm2000, TAFATNEB, malc, ting tsai huang, aslam, ykhackhack, zrilek, slowet
  Earthquake-Induced Collapse Simulation of a Super-Tall Mega-Braced Frame-Core Tube Bu TAFATNEB 1 8,105 10-30-2020, 08:45 AM
Last Post: gbn1980
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 5,676 12-26-2014, 09:49 PM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 5,893 10-08-2014, 02:06 PM
  Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 4,813 09-05-2014, 02:03 PM
  Seismic performance of concrete frame structures reinforced with superelastic shape TAFATNEB 0 5,839 09-05-2014, 01:59 PM
  EXPERIMENTAL MULTI-LEVEL SEISMIC PERFORMANCE ASSESSMENT OF 3D RC FRAME DESIGNED FOR D TAFATNEB 0 3,934 06-03-2014, 09:01 PM
  Seismic collapse analysis on core-outrigger structures TAFATNEB 0 3,596 04-26-2014, 11:15 AM
