Civil Engineering Association eBooks Journals, Papers and Presentations EXPERIMENTAL MULTI-LEVEL SEISMIC PERFORMANCE ASSESSMENT OF 3D RC FRAME DESIGNED FOR D
06-03-2014, 09:01 PM
EXPERIMENTAL MULTI-LEVEL SEISMIC PERFORMANCE ASSESSMENT OF 3D RC FRAME DESIGNED FOR DAMAGE AVOIDANCE
Author: Brendon A Bradley1* , Rajesh P Dhakal1 , John B Mander1 , Louman Li1 . 1 Department of Civil Engineering, University of Canterbury, , New Zealand | Size: 591 KB | Format: PDF | Quality: Unspecified | pages: 33
This paper experimentally investigates the application of damage avoidance design (DAD) philosophy to moment resisting frames with particular emphasis on detailing of rocking interfaces. An 80% scale 3-dimensional rocking beam-column joint sub-assembly designed and detailed based on damage avoidance principles is constructed and tested.
Incremental dynamic analysis (IDA) is used to select ground motion records to be applied to the sub-assembly to conduct a multi-level seismic performance assessment (MSPA).
Analyses are conducted to obtain displacement demands due to the selected near and medium
field ground motions that represent different levels of seismic hazard. Thus predicted
displacement time histories are applied to the sub-assembly to conduct quasi-earthquake displacement (QED) tests. The sub-assembly performed well reaching drifts up to 4.7% with only minor spalling occurring at rocking beam interfaces and minor flexural cracks in beams.
Yielding of post-tensioning tendons occurred, but the sub-assembly did not collapse. The externally attached energy dissipaters provided large hysteretic dissipation during large drift
cycles. The sub-assembly satisfied all three seismic performance requirements, thereby verifying the superior performance of the DAD philosophy.
  • rezart, malc, vardan, blaze, zrilek, Clouseau
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,270 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,106 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  2nd ATC-SEI Conference on Improving the Seismic Performance of Existing Buildings and RyanRS 0 5,199 10-29-2015, 12:55 AM
Last Post: RyanRS
  Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 5,859 07-19-2015, 07:24 AM
Last Post: Wolverine883
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 5,812 12-26-2014, 09:49 PM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,046 10-08-2014, 02:06 PM
  Seminar Achieving Seismic Performance in Steel Connections RyanRS 2 7,846 09-22-2014, 09:21 PM
Last Post: inge911
