Civil Engineering Association eBooks Journals, Papers and Presentations Pushover and Seismic Response of Foundations on Stiff Clay: Analysis with P-Delta Eff
11-23-2013, 11:32 PM
Pushover and Seismic Response of Foundations on Stiff Clay: Analysis with P-Delta Effects
Author: Andriani I. Panagiotidou, George Gazetas, and Nikos Gerolymos | Size: 1.4 MB | Format: PDF | Quality: Unspecified | Publisher: Earthquake Spectra, Volume 28, No. 4, pages 1589–1618, November 2012; © 2012, Earthquake Engineering Research Institu | Year: 2012 | pages: 30
[Image: 68508770880169823257.png]
Finite-element analyses are performed for the response to lateral monotonic, slow-cyclic, and seismic loading of rigid footings carrying tall slender structures and supported on stiff clay. The response involves mainly footing rotation under the action of overturning moments from the horizontal external force on—or the developing inertia at—the mass of the structure, as well as from the aggravating contribution of its weight (P-delta effect). Emphasis is given to the conditions for collapse of the soil-foundation-structure system. Two interconnected mechanisms of nonlinearity are considered: detachment from the soil with subsequent uplifting of the foundation (geometric nonlinearity) and formation of bearingcapacity failure surfaces (material inelasticity). The relation between monotonic behavior (static “pushover”), slow-cyclic behavior, and seismic response is explored parametrically. We show that with “light” structures uplifting is the dominant mechanism that may lead to collapse by dynamic instability (overturning), whereas “very heavy” structures mobilize soil failure mechanisms, leading to accumulation of settlement, residual rotation, and ultimately collapse.
  • rezart, chenamoy, vardan, malc, blaze, SCREAM7890, ssobhan, cace-01, ashcivilea, slowet
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 5,812 12-26-2014, 09:49 PM
  Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 5,809 10-21-2014, 08:57 AM
Last Post: Munykong
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 5,823 09-05-2014, 01:46 PM
  Pushover Analysis of I-5 RAVENNA Bridge TAFATNEB 0 4,892 08-14-2014, 08:26 AM
  Seismic response of earth dams: some recent developments TAFATNEB 0 4,164 08-12-2014, 09:33 AM
  The evaluation of impedance functions in the analysis of foundations vibrations using TAFATNEB 1 5,361 08-11-2014, 10:26 AM
  Estimation of hysteretic energy demand using concepts of modal pushover analysis TAFATNEB 0 4,427 08-10-2014, 02:52 PM
