Civil Engineering Association eBooks Journals, Papers and Presentations The evaluation of impedance functions in the analysis of foundations vibrations using
08-30-2013, 11:16 PM (This post was last modified: 08-31-2013, 12:24 AM by usman.)
The evaluation of impedance functions in the analysis of foundations vibrations using boundary element method
Author: E. C¸ elebia, *, S. Fıratb , _ I. C¸ ankayac | Size: 2.2 MB | Format: PDF | Quality: Unspecified | Publisher: Applied Mathematics and Computation 173 (2006) 636–667 | Year: 2006 | pages: 32
The basic step in the substructure approach based on discretization of the soil medium
for the soil–structure interaction problems is to determine the impedance functions which are defined as the complex dynamic-stiffness coefficients of the soil-footing system are used in the analysis of foundations vibrations. In this study, the discrete values of impedance functions over wide ranges of frequency-factors are presented for both surface- supported and embedded foundations. The numerical results are obtained by using the substructure approach in the frequency domain which is formulated on basis of the Boundary Element Method derived from the fundamental solution for a homogeneous, isotropic and linear-elastic continuum. To further demonstrate in practical applications and to show the solutions of this type of problems to civil engineers, a comprehensive parametric analysis and systematic calculations are performed with various controlling parameters to evaluate the dynamic response of the vibrating soil–foundation system. In
  • gulilero, malc, blaze, bigone, jcbv, kowheng, zrilek, lasalleguy
08-11-2014, 10:26 AM
Author: E. C¸ elebi a,*, S. Fırat b, _I. C¸ ankaya c | Size: 3.2 MB | Format: PDF | Quality: Unspecified | Publisher: Applied Mathematics and Computation 173 (2006) 636–667 | Year: 2006 | pages: 32
[Image: 14642745989988761181.jpg]
The basic step in the substructure approach based on discretization of the soil medium for the soil–structure interaction problems is to determine the impedance functions which are defined as the complex dynamic-stiffness coefficients of the soil-footing system are used in the analysis of foundations vibrations. In this study, the discrete values of impedance functions over wide ranges of frequency-factors are presented for both surface- supported and embedded foundations. The numerical results are obtained by using the substructure approach in the frequency domain which is formulated on basis of the Boundary Element Method derived from the fundamental solution for a homogeneous, isotropic and linear-elastic continuum. To further demonstrate in practical applications and to show the solutions of this type of problems to civil engineers, a comprehensive parametric analysis and systematic calculations are performed with various controlling parameters to evaluate the dynamic response of the vibrating soil–foundation system.
  • blaze, vardan, warlord1, gulilero, shadabg
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 5,630 09-05-2014, 01:46 PM
  Vibrations of machine foundations and surrounding soil TAFATNEB 0 3,974 08-11-2014, 10:05 AM
  Analysis of machine foundation vibrations: state of the art TAFATNEB 0 4,002 08-11-2014, 10:00 AM
  Pushover and Seismic Response of Foundations on Stiff Clay: Analysis with P-Delta Eff TAFATNEB 0 3,693 11-23-2013, 11:32 PM
  Analysis of Ultimate Loads of Shallow Foundations shadabg 0 3,931 11-02-2012, 12:37 PM
Last Post: shadabg
  Analysis and Design of Drilled Shaft Foundations Socketed into Rock shadabg 0 3,948 10-04-2012, 08:48 AM
Last Post: shadabg
  Pros and cons analysis of seismic evaluation cve_jule 0 3,813 09-02-2011, 12:12 PM
Last Post: cve_jule
