Civil Engineering Association eBooks Journals, Papers and Presentations Estimation of hysteretic energy demand using concepts of modal pushover analysis
08-10-2014, 02:52 PM
Author: Tholen Prasanth , Siddhartha Ghosh , d Kevin R. Collins | Size: 235 KB | Format: PDF | Quality: Unspecified | Publisher: EARTHQUAKE ENGINEERING AND STRUCTURAL DYNAMICS Earthquake Engng Struct. Dyn. 2008; 37:975–990 Published online 17 March 2008 in Wiley InterScience (www.interscience.wiley.com). DOI: 10.1002/eqe.802 | Year: 2008 | pages: 16
Hysteretic energy dissipation in a structure during an earthquake is the key factor, besides maximum displacement, related to the amount of damage in it. This energy demand can be accurately computed
only through a nonlinear time-history analysis of the structure subjected to a specific earthquake ground acceleration. However, for multi-story structures, which are usually modeled as multi-degree of freedom
(MDOF) systems, this analysis becomes computation intensive and time consuming and is not suitable for adopting in seismic design guidelines. An alternative method of estimating hysteretic energy demand on MDOF systems is presented here. The proposed method uses multiple ‘generalized’ or ‘equivalent’ single
degree of freedom (ESDOF) systems to estimate hysteretic energy demand on an MDOF system within the
context of a ‘modal pushover analysis’. This is a modified version of a previous procedure using a single ESDOF system. Efficiency of the proposed procedure is tested by comparing energy demands based on
this method with results from nonlinear dynamic analyses of MDOF systems, as well as estimates based on the previous method, for several ground motion scenarios. Three steel moment frame structures, of 3-, 9-, and 20-story configurations, are selected for this comparison. Bias statistics that show the effectiveness of the proposed method are presented. In addition to being less demanding on the computation time and
complexity, the proposed method is also suitable for adopting in design guidelines, as it can use response spectra for hysteretic energy demand estimation.
  • vardan, blaze, jcbv, zrilek, malc, PinkPant, civilgen
  Pushover Analysis of I-5 RAVENNA Bridge TAFATNEB 0 4,898 08-14-2014, 08:26 AM
  Pushover analysis of multi-st orey cantilever wall systems TAFATNEB 0 4,154 08-10-2014, 02:48 PM
  Comparison of Static and Dynamic Pushover Analysis in Assessment of the Target Displa TAFATNEB 0 4,694 08-10-2014, 02:42 PM
  Some Remarks on the Seismic Demand Estimation in the Context of Vulnerability Assessm TAFATNEB 0 3,833 05-10-2014, 10:21 AM
  ANALYSIS ON SEISMIC PERFORMANCE OF ENERGY DISSIPATION SUBSIDIARY PIERS CONSIDERING FO TAFATNEB 0 4,038 05-02-2014, 09:27 AM
  Modal Pushover Analysis of SAC Buildings TAFATNEB 0 4,071 04-26-2014, 06:15 PM
  Behavior of high frequency modal responses in non linear seismic  analysis  TAFATNEB 0 4,356 04-17-2014, 09:57 AM
