Civil Engineering Association eBooks Journals, Papers and Presentations Comparison of Static and Dynamic Pushover Analysis in Assessment of the Target Displa
08-10-2014, 02:42 PM
Comparison of Static and Dynamic Pushover Analysis in Assessment of the Target Displacement
Author: Fayaz R. Rofooei1, Nader K. Attari , Ali Rasekh , Amir H. Shodja | Size: 237 KB | Format: PDF | Quality: Unspecified | Publisher: International Journal of Civil Engineerng. Vol. 4 , No. 3, September 2006 | Year: 2006 | pages: 14
Pushover analysis is a simplified nonlinear analysis technique that can be used to estimate the dynamic demands imposed on a structure under earthquake excitations. One of the first steps taken in this approximate solution is to assess the maximum roof displacement, known as target displacement, using the base shear versus roof displacement diagram. That could be done by the so-called dynamic pushover analysis, i.e. a dynamic time history analysis of an equivalent single degree of freedom model of the original system, as well as other available approximate static
methods. In this paper, a number of load patterns, including a new approach, are considered to construct the related pushover curves. In a so-called dynamic pushover analysis, the bi-linear and tri-linear approximations of these pushover curves were used to assess the target displacements by performing dynamic nonlinear time history analyses. The results obtained for five different special moment resisting steel frames, using five earthquake records were compared with those resulted from the time history analysis of the original system. It is shown that the dynamic pushover analysis approach, specially, with the tri-linear approximation of the pushover curves, proves to have a better accuracy in assessing the target displacements. On the other hand, when nonlinear static procedure seems adequate, no specific preference is observed in using more complicated static procedures (proposed by codes) compared to the simple first mode target displacement assessment.
  • blaze, vardan, amindoxiti, chenamoy, jcbv, learner20, zrilek, gulilero, malc, PinkPant, civilgen
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,272 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Loading Pattern and Spatial Distribution of Dynamic Wind Load and Comparison of Wind TAFATNEB 0 4,390 09-05-2014, 01:40 PM
  Pushover Analysis of I-5 RAVENNA Bridge TAFATNEB 0 4,892 08-14-2014, 08:26 AM
  Estimation of hysteretic energy demand using concepts of modal pushover analysis TAFATNEB 0 4,429 08-10-2014, 02:52 PM
  Pushover analysis of multi-st orey cantilever wall systems TAFATNEB 0 4,142 08-10-2014, 02:48 PM
  SEISMIC BEHAVIOR OF DAMAGED BUILDINGS: A COMPARISON OF STATIC AND DYNAMIC NONLINEAR A TAFATNEB 0 4,080 08-10-2014, 02:06 PM
  Dynamic Analysis of Reinforced Concrete Building with Plan Irregularities TAFATNEB 0 4,584 05-30-2014, 01:43 PM
