Civil Engineering Association eBooks Journals, Papers and Presentations Development of Ring-Shaped Steel Plate Shear Walls
 asim99
User ID: 9774
Threads: 476
Likes: 6,383 in 594 posts
Given Likes: 377
Points:54,091 EP
06-15-2013, 04:38 PM
Author: Maurya, A., Egorova, N., and Eatherton, M. | Size: 1.2 MB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 2013 | pages: 12
Steel plate shear walls (SPSWs) are an attractive option for seismic lateral
load resisting systems for both new and retrofit construction. However, the current
approach to SPSWs in the U.S. typically uses very thin web plates, large boundary
elements, and requires costly moment connections. Resulting SPSWs suffer from
early buckling and subsequent tension-only plate behavior which leads to pinched
hysteretic behavior, reduced stiffness, and limited energy dissipation. Moreover, the
large boundary elements and moment connections can make SPSW less economical
than concentrically braced frames.
This paper describes a new type of SPSW referred to as ring-shaped steel
plate shear walls (RS-SPSWs) which build on the advantages of steel plate shear
walls, but have improved seismic performance, develop reduced demands on
boundary elements, and allow simple shear beam-to-column connections. RS-SPSW
reduces buckling by utilizing a unique pattern of ring-shaped cut-outs. The ring shape
acts to remove excess material in the direction transverse to the tension direction thus
reducing the amount of buckling. Its geometric features also result in more
independent variables which can be varied to separately tune aspects of system
behavior like strength, stiffness, ductility and energy absorption of the shear wall
system. This paper focuses on the effect of geometric design variables on system
behavior. After validation against experimental test results, finite element modeling
is used to perform a parametric study.
[-] The following 8 users Like asim99's post:8 users Like asim99's post
  • fred2010, ssobhan, Jackass, devilmaycry, warbeast, malc, kowheng, slowet
  Experiment and Analysis on X-Shaped Reinforced Concrete Joint in Diagrid Structures asim99 1 5,747 04-20-2018, 05:19 PM
Last Post: munycamsec
  Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 4,554 03-16-2016, 09:41 AM
  Development of a Precast Concrete Shear-Wall System Requiring Special Code Acceptance TAFATNEB 0 5,037 02-12-2015, 01:32 PM
  PUSHOVER ANALYSIS FOR PERFORMANCE BASED-SEISMIC DESIGN OF RC FRAMES WITH SHEAR WALLS TAFATNEB 0 4,802 04-11-2014, 09:13 AM
  Seismic strengthening of RC structures with exterior shear walls TAFATNEB 0 3,710 11-24-2013, 12:03 AM
  SEISMIC LATERAL FORCE DISTRIBUTION FOR DUCTILITY-BASED DESIGN OF STEEL PLATE SHEAR WA TAFATNEB 0 3,768 08-31-2013, 10:41 AM
  OPTIMIZED USE OF THE OUTRIGGER SYSTEM TO STIFFEN THE COUPLED SHEAR WALLS IN TALL BUIL asim99 0 3,355 12-31-2012, 01:46 AM
Last Post: asim99
