Civil Engineering Association eBooks Journals, Papers and Presentations OPTIMIZED USE OF THE OUTRIGGER SYSTEM TO STIFFEN THE COUPLED SHEAR WALLS IN TALL BUIL
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
12-31-2012, 01:46 AM
OPTIMIZED USE OF THE OUTRIGGER SYSTEM TO STIFFEN THE COUPLED SHEAR WALLS IN TALL BUILDINGS
Author: NAVAB ASSADI ZEIDABADI , KAMAL MIRTALAE AND BARZIN MOBASHER | Size: 250 KB | Format: PDF | Quality: Unspecified | Publisher: NAVAB ASSADI ZEIDABADI , KAMAL MIRTALAE1 AND BARZIN MOBASHER | Year: 2004 | pages: 19
[Image: 59239431096351640066.jpg]
Based on the conventional yet accurate continuum approach, a general analysis is presented for a pair of coupled
shear walls, stiffened by an outrigger and a heavy beam in an arbitrary position on the height. Subsequently, a
parametric study is presented to investigate the behavior of the structure. The optimum location of the outrigger
and the parameters affecting its position were also investigated. The results showed that the behavior of the structure
can be significantly influenced by the location of the outrigger. It was also indicated that in most ordinary
cases the best location of the structure to minimize top drift is somewhere between 0·4 to 0·6 of the height of the
structure. Though this method is not a substitute for the finite element method, it gives an initial simple solution
to determine the size and position of outrigger, stiffening beam and coupled shear walls in the preliminary design
stages.
[-] The following 6 users Like asim99's post:6 users Like asim99's post
  • knrsa, malc, ting tsai huang, erthqkengnr™, KhaLed-S.E, ruaumoko
  Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 4,710 03-16-2016, 09:41 AM
  Development of a Precast Concrete Shear-Wall System Requiring Special Code Acceptance TAFATNEB 0 5,237 02-12-2015, 01:32 PM
  Seismic collapse analysis on core-outrigger structures TAFATNEB 0 3,595 04-26-2014, 11:15 AM
  Seismic performance of a 12-storey ductile concrete shear wall system designed accord TAFATNEB 0 4,279 04-21-2014, 10:41 PM
  PUSHOVER ANALYSIS FOR PERFORMANCE BASED-SEISMIC DESIGN OF RC FRAMES WITH SHEAR WALLS TAFATNEB 0 4,936 04-11-2014, 09:13 AM
  Seismic strengthening of RC structures with exterior shear walls TAFATNEB 0 3,880 11-24-2013, 12:03 AM
  Effects of plastic hinge properties in nonlinear analysis of reinforced concrete buil TAFATNEB 0 3,983 11-23-2013, 12:05 AM
