Evaluation of progressive collapse potential of multi-story moment resisting steel fr
Evaluation of progressive collapse potential of multi-story moment resisting steel frame buildings under lateral loading
Author: H.R. Tavakoli, A. Rashidi Alashti | Size: 1.2 MB | Format: PDF | Quality: Unspecified | Publisher: Science Direct | Year: 2012 | pages: 10
The aim of this study is to investigate whether MRF steel structures that have been designed
based on seismic codes, are able to resist progressive collapse with damaged columns in different locations
under seismic loading.
For this purpose, 3-D and 2-D push-over analysis of structures is carried out. The progressive collapse
potential has been assessed in connection with 5 and 15-story buildings with 4 and 6 bays by applying the
alternate load path method recommended in UFC guidelines.
Member removal in this manner is intended to represent a situation where an extreme event, such as
vehicle impact or past earthquake shock or construction error, may cause a critical column, as a result of
local or global buckling, to lose a part or whole of its load bearing capacity.
In contrast with 3-D models, two-dimensional frames represent a higher sensitivity to base shear
reduction and element removal. In the case of middle column removal, the structure is more robust than
in a corner column removal situation. The influence of story number, redundancy and location of critical
eliminated elements has been discussed.
a- Follow the Forum Rules.
[-] The following 8 users say Thank You to asim99 for this post:
  • Jackass, blaze, gulilero, narendra, devilmaycry, Dell_Brett, kowheng, malc
Progressive collapse analysis of an RC building with exterior partially infilled wall asim99 1 1,665 03-01-2017, 05:02 PM
Last Post: pezhmankhan
Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 1,454 09-05-2014, 03:03 PM
Progressive Collapse of Multi-Storey Buildings due to Sudden Column Loss –Part II: Ap TAFATNEB 0 1,178 05-09-2014, 03:00 PM
Retrofit Methods to Mitigate Progressive Collapse TAFATNEB 0 1,564 05-09-2014, 12:44 PM
Progressive Collapse of Bridges—As pects of Analysis and Design TAFATNEB 0 1,050 05-02-2014, 10:02 AM
