Civil Engineering Association eBooks Journals, Papers and Presentations Seismic Design of Steel Special Moment Frames: A Guide for Practicing Engineers
 yanburak
User ID: 27551
Threads: 93
Likes: 821 in 94 posts
Given Likes: 421
09-19-2010, 06:45 PM
[Image: 72289393402367504958.jpg]
This report was prepared for the Building and Fire Research Laboratory of the National Institute of Standards and Technology under contract
number SB134107CQ0019, Task Order 68003. The statements and conclusions contained in this report are those of the authors and do not
imply recommendations or endorsements by the National Institute of Standards and Technology.
This Technical Brief was produced under contract to NIST by the NEHRP Consultants Joint Venture, a joint venture of the Applied Technology
Council (ATC) and the Consortium of Universities for Research in Earthquake Engineering (CUREE). While endeavoring to provide practical
and accurate information in this publication, the NEHRP Consultants Joint Venture, the authors, and the reviewers do not assume liability for,
nor make any expressed or implied warranty with regard to, the use of its information. Users of the information in this publication assume all
liability arising from such use.
37 pages - 1,4 Mb
[-] The following 13 users Like yanburak's post:13 users Like yanburak's post
  • blaze, Dell_Brett, hapsea, Apache, avscorreia, oanm2000, yantonegr, orambo, carolinandra, kowheng, valinhas, maad59, subin91
Likes: 8,185 in 1,337 posts
08-04-2021, 07:45 AM (This post was last modified: 08-15-2021, 10:15 PM by oanm2000. Edit Reason: N/A )
Seismic Design of Reinforced Concrete Special Moment Frames: A Guide for Practicing Engineers
Author(s)/Editor(s): Jack P. Moehle, John D. Hooper, Chris D. Lubke | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: NEHRP | Year: August, 2008 | pages: 31
[Image: 21205306916022007959.png]
Reinforced concrete special moment frames are used as part of seismic force-resisting systems in buildings that are designed to resist earthquakes. Beams, columns, and beam-column joints in moment frames are proportioned and detailed to resist flexural, axial, and shearing actions that result as a building sways through multiple displacement cycles during strong earthquake ground shaking. Special proportioning and detailing requirements result in a frame capable of resisting strong earthquake shaking without significant loss of stiffness or strength. These moment-resisting frames are called “Special Moment Frames” because of these additional requirements,which improve the seismic resistance in comparison with less stringently detailed Intermediate and Ordinary Moment Frames.
2nd edition 2016
1st edition 2008
[-] The following 11 users Like poolmand's post:11 users Like poolmand's post
  • sodapas, Dell_Brett, versiondemo, blaze, cace-01, pedzaquino, mgdario, PinkPant, kowheng, zrilek, oanm2000
 Wijono
User ID: 33767
Threads: 0
Likes: 56 in 8 posts
Given Likes: 691
08-04-2021, 08:44 PM
(08-04-2021, 07:45 AM)poolmand Wrote:
Seismic Design of Reinforced Concrete Special Moment Frames: A Guide for Practicing Engineers 2nd Edition
The posted material shall be the previous one. The latest / 2nd edition as mentioned in the title shall have "Second Edition" stated in the cover. The material is accesible for free through the link below:
[-] The following 16 users Like Wijono's post:16 users Like Wijono's post
  • mgdario, Dell_Brett, PinkPant, RajaK, kowheng, Administrator , zrilek, Aviator, subin91, rami1976, simanta, caleno, KMABD, Hengki, cristi, oanm2000
  The Structural Design of Tall and Special Buildings - Papers lisine 3 11,492 12-16-2020, 02:31 AM
Last Post: CAMSECT
  Propagating Waves in the Steel, Moment-Frame Factor Building Recorded during Earthqua TAFATNEB 0 4,507 07-03-2015, 09:57 PM
  Retrofitting steel special moment frame using ADAS metallic yielding dampers TAFATNEB 0 4,731 12-28-2014, 08:45 AM
  Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 4,770 09-05-2014, 02:03 PM
  Evaluation of the seismic performance of a three-story ordinary moment-resisting conc TAFATNEB 0 3,733 04-26-2014, 06:25 PM
  Influence of Structural Parame ters to the Seismic Collapse Resistance of RC Frames i TAFATNEB 0 3,748 04-18-2014, 05:39 PM
  PUSHOVER ANALYSIS FOR PERFORMANCE BASED-SEISMIC DESIGN OF RC FRAMES WITH SHEAR WALLS TAFATNEB 0 4,905 04-11-2014, 09:13 AM
