Civil Engineering Association eBooks Journals, Papers and Presentations Shear Strength Estimation of Sandy Soils Using Shear Wave Velocity
 AlmostThere
Member
User ID: 46514
Threads: 35
Likes: 101 in 22 posts
Given Likes: 48
Points:2,901 EP
04-15-2013, 10:30 AM
Author: Cha, Minsu; Cho, Gye-Chun | Size: 339 KB | Format: PDF | Quality: Unspecified | Publisher: Geotechnical Testing Journal (GTJ) | Year: 2007 | pages: 12
Abstract
Typically, shear strength is associated with large strain phenomena, while shear wave propagation is associated with small strain phenomena. Yet, the effective stress and void ratio, both key determinants of sandy soil shear strength, are also the primary factors affecting shear wave velocity. This study presents a shear wave velocity-void ratio-shear strength correlation through experimental tests. Natural sands taken from various reclaimed or recently deposited sandy fields are used for reconstituting specimens at different void ratios in an oedometer cell. Shear wave velocities are measured while changing the state of the stress in the cell for each specimen prepared at a specific void ratio. The relationship between shear wave velocity and vertical effective stress is found at extreme values of void ratios (emin and emax). Direct shear tests are also performed on specimens with various void ratios. Experimental results show that the internal friction angle of each sand type increases with decreasing void ratio, rendering a unique relationship between friction angle and void ratio. Finally, a procedure is suggested to evaluate the in-situ shear strengths of a sandy soil based on in-situ shear wave velocities. Results show that the suggested method effectively estimates in-situ shear strength.
shear wave velocity, void ratio, shear strength
[-] The following 7 users Like AlmostThere's post:7 users Like AlmostThere's post
  • freequo, blaze, shadabg, jacs127, malc, daywalker, kowheng
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 9,779 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 3,299 03-16-2016, 09:41 AM
  Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concre yakwetu 1 5,377 07-08-2015, 08:02 AM
Last Post: PinkPant
  SEISMIC DESIGN FACTORS FOR PRECAST CONCRETE SHEAR WALL PARKING GARAGES TAFATNEB 0 4,032 02-12-2015, 01:39 PM
  Development of a Precast Concrete Shear-Wall System Requiring Special Code Acceptance TAFATNEB 0 3,952 02-12-2015, 01:32 PM
  CONCRETE SHEAR WALL DESIGN aslam 2 6,861 08-20-2014, 07:47 AM
  A NEW MODEL FOR JOINT SHEAR FAILURE OF REINFORCED CONCRETE INTERIOR BEAM-TO-COLUMN JO TAFATNEB 0 2,844 06-01-2014, 03:35 PM
