Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concre
Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concrete Slabs
Author: Maria Anna Polak and Wensheng Bu | Size: 0.5 MB | Format: PDF | Quality: Original preprint | Publisher: ACI Structural Journal | Year: 2013
Abstract:
This study addresses design aspects for the punching shear bolt retrofitting system for reinforced concrete flat slabs supported on columns. Shear bolts are an external type of reinforcement installed in existing slabs by first drilling small holes through the slab thickness, installing the bolts into them, and tightening the bolt nuts. Previous experimental research at the University of Waterloo showed the effectiveness of this system in increasing strength and ductility of existing slabs, with little changes in the slab’s appearance. The procedures for the design of the shear bolts and their installation in slabs are proposed in the paper. Recommendations are provided regarding the stem diameter, the head area and thickness, and the spacing and the layout of the bolts in a plane of a slab.
Proud Member of Best Civil Engineering Forum since May 2009
[-] The following 18 users say Thank You to yakwetu for this post:
  • shaker, Dell_Brett, ssobhan, highcivil, blaze, PinkPant, amindoxiti, Songoku, zrilek, Jackass, ykhackhack, sodapas, K.Lee, draluka, subin91, malc, oanm2000, araza023
Use regular forum pass
PinkPant
[-] The following 8 users say Thank You to PinkPant for this post:
  • concreteok, Dell_Brett, amindoxiti, oanm2000, sodapas, gulilero, araza023, Trishu999
Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 5,834 08-01-2017, 10:19 AM
Last Post: abdulazizk
Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 1,163 03-16-2016, 10:41 AM
SEISMIC DESIGN FACTORS FOR PRECAST CONCRETE SHEAR WALL PARKING GARAGES TAFATNEB 0 1,960 02-12-2015, 02:39 PM
Development of a Precast Concrete Shear-Wall System Requiring Special Code Acceptance TAFATNEB 0 1,734 02-12-2015, 02:32 PM
CONCRETE SHEAR WALL DESIGN aslam 2 3,201 08-20-2014, 08:47 AM
