Static Pushover Analysis Based on an Energy-Equivalent SDOF System
Current time: 12-12-2018, 11:22 AM
Author: asim99
Last Post: ssobhan
Replies 1
Views 1622
Author: Grigorios Manoukas,Asimina Athanatopoulou, and Ioannis Avramidis | Size: 1 MB | Format: PDF | Quality: Unspecified | Publisher: Earthquake Spectra | Year: 2011 | pages: 19
In this paper, a new energy-based pushover procedure is presented in order
to achieve an approximate estimation of structural performance under strong
earthquakes. The steps of the proposed methodology are quite similar to those
of the well-known displacement modification method. However, the determination
of the characteristics of the equivalent single-degree-of-freedom (E-SDOF)
system is based on a different rational concept. Its main idea is to determine the
E-SDOF system by equating the external work of the lateral loads acting on the
multi-degree-of-freedom (MDOF) system under consideration to the strain
energy of the E-SDOF system. After a brief outline of the theoretical background,
a representative numerical example is given. Finally, the accuracy of
the proposed method is evaluated by an extensive parametric study which shows
that, in general, it provides better results compared to those produced by other
similar procedures
a- Follow the Forum Rules.
[-] The following 11 users say Thank You to asim99 for this post:
  • LiviuM, ssobhan, 3fan, stigtg, kowheng, eRw1n, Dell_Brett, ting tsai huang, Grunf, rezart, TAFATNEB
Dear 3fan
Get it here;
For get high quality pdf for paper, you can go to the Professor IOANNIS E. AVRAMIDIS 's personal webpage as the following paper and print the requested paper;
“His blue eyes are often bloodshot, and their expression indicates that there is a helpless, baffled soul squirming around inside this doughty fortress.” Prue by Alice Munro, ©1982.
[-] The following 13 users say Thank You to ssobhan for this post:
  • LiviuM, 3fan, jcbv, seriousboy, gulilero, eRw1n, malc, Dell_Brett, andersen3, Grunf, denysitorus, rezart, TAFATNEB
Pushover Analysis of I-5 RAVENNA Bridge TAFATNEB 0 1,278 08-14-2014, 09:26 AM
Estimation of hysteretic energy demand using concepts of modal pushover analysis TAFATNEB 0 1,182 08-10-2014, 03:52 PM
Comparison of Static and Dynamic Pushover Analysis in Assessment of the Target Displa TAFATNEB 0 1,022 08-10-2014, 03:42 PM
Comparison between Static and Dynamic Analysis of Elevated Water Tank” TAFATNEB 0 1,260 05-10-2014, 10:18 AM
Modal Pushover Analysis of SAC Buildings TAFATNEB 0 1,145 04-26-2014, 07:15 PM
