Civil Engineering Association Forum Discussion Suggestion & Complains Archive Edit problem
Thread Closed
Edit problem
 apocalipse
Portugal
User ID: 41527
Threads: 105
Likes: 790 in 87 posts
Given Likes: 922
Points:12,693 EP
01-19-2013, 11:13 PM
Hello,
I don't know whats going on, but the edit bar(bold, italic, letters size, etc. options) is not showing anymore on my screen in the last days.
Can someone help me.
Thank you,
apocalipse
Points:136,043 EP
01-19-2013, 11:38 PM
I believe you need to be more specific. Show us some screenshot or detailed explanation of the problem.
G
 apocalipse
Portugal
User ID: 41527
Threads: 105
Given Likes: 922
Points:12,693 EP
01-20-2013, 12:36 PM (This post was last modified: 01-20-2013, 12:41 PM by BennyP.)
Maybe a screenshot will be helpful. As i said i don't have the edit bar option on my posts.
[Image: 95846927155715296745.png]
apocalipse
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,981 in 4,091 posts
Given Likes: 612
Points:282,462 EP
01-20-2013, 12:54 PM (This post was last modified: 01-20-2013, 01:11 PM by BennyP.)
Instead of posting this useless image (in a transparent link) specify your operation system and your browser (including the version).
The description in your previous post (missing edit bar) is enough to understand your problem but you don't answer the question about detailed explanqtion.
Do you see a message about secure and no secure items at the lower row of your screen ?
The forum URL is https://... or http://.... ?
 apocalipse
Portugal
User ID: 41527
Threads: 105
Given Likes: 922
Points:12,693 EP
01-20-2013, 03:21 PM
My operating system is Windows 7 ultimate 64 bits and the browser is Google Chrome Version 24.0.1312.52 m
As you see in the image i posted above i can not edit my post,, like insert protected links, change the colours of the letters, the size, the align text options,etc...
And yes i see a message about secure items, the forum URL is https://
It says that my connection with civilea is encrypted at 256 bits and also that the connections doesn't use SSL compression.
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
Points:282,462 EP
01-20-2013, 03:50 PM
Because i can't see any reason to install Google Chrome i will give you the procedure in Internet Explorer (v 9.0) and i suppose many other users have the same problem in IE and not only for edit tools but for expanding forum sections (+) in the main page and maybe more.
Try to find the parallel way in Chrome.
Internet Options
Security
Custom Level
Miscellaneous
Display mixed content
Enable
OK
OK
Close and Restart the Browser.
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 277
Likes: 21,144 in 2,346 posts
Given Likes: 4238
Points:549,394 EP
01-20-2013, 06:15 PM
your problem insist or have been solved?
 apocalipse
Portugal
User ID: 41527
Threads: 105
Given Likes: 922
Points:12,693 EP
01-20-2013, 07:14 PM
With Google Chrome i could not solve it, but with Internet explorer the problem does not appear.
In the meantime every time i want to post, guess i will use IExplorer, at least to the moment i or someone else knows the solution with Chrome.
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 277
Given Likes: 4238
Points:549,394 EP
01-20-2013, 07:43 PM
try to use forum without SSL (http://form.civilea.com)
[-] The following 1 user Likes Administrator 's post:1 user Likes Administrator 's post
  • apocalipse
 apocalipse
Portugal
User ID: 41527
Threads: 105
Given Likes: 922
Points:12,693 EP
01-20-2013, 07:50 PM
Thanks it solved the problem. The editing tools right now are showing in the screen.
regards,
apocalipse
  [Suggestion] Edit "Engineering Problems" desciption cernogratz 2 9,341 02-15-2017, 11:00 AM
Last Post: Administrator
  【Suggestion】 Edit Time Limit netsonicyxf 1 5,501 02-20-2013, 09:18 AM
Last Post: LiviuM
