Civil Engineering Association Forum Discussion Suggestion & Complains Archive 【Suggestion】 Edit Time Limit
 netsonicyxf
Senior Member
Banned
User ID: 12185
Threads: 141
Likes: 134 in 66 posts
Given Likes: 66
02-20-2013, 02:51 AM
After users post their threads, they only have limited time to edit them.
Why not allow user to edit them anytime they want?
What's the purpose to limit the edit time?
E.g. I reply this thread
but forget to use
Quote:
Now I can't edit my posts because the edit time limited, although I want to .
[/code]I might get a warning because some Admin or Admin Deputy might think I didn't follow the rules.
[-] The following 1 user Likes netsonicyxf's post:1 user Likes netsonicyxf's post
  • andersen3
 LiviuM
Christmas Island
User ID: 430
Threads: 90
Likes: 3,228 in 559 posts
Given Likes: 1706
02-20-2013, 09:18 AM (This post was last modified: 02-20-2013, 09:20 AM by LiviuM.)
Dear netsonicyxf,
You are user since Jan 2010, you have a lot of warnings for not following the rules.
You should read the rules, understand them, ask questions if you don't, read the manual made by Grunf.
After all that you may start making posts according to rules.
Write the post have a look at it, click the preview button, check if it's according to rules, if it's in the right section, and after click the final post button.
Use the edit option only if there's a mistake or you forgot something.
The purpose to limit the edit time is quite simple:
1) You are responsible for what you write, share here. This responsibility is enforced by the limit in editing time. So what you write stays until deleted by forum staff or scripts.
If you write bad things they stay, if you write good things they stay.
2) Changing a post will not notify users that already red it the first time.
See this posts of my own:
Although as a moderator I can edit Post: #5 and correct my engineering mistake even now; It is not right for those who have already red it. And so there's post #6 which fixes the engineering mistake. So editing is not ethical or the right thing for others.
3) Users receive thanks/agree or even points for what they write. If they change what they wrote the agree/thanks or points should be canceled. This is not ok for a forum which grows by non editable contents.
4) ... other I don't see.
[-] The following 8 users Like LiviuM's post:8 users Like LiviuM's post
  • Dell_Brett, Administrator , BennyP, usman, kowheng, gulilero, albani, HofOblivion
  [Suggestion] Edit "Engineering Problems" desciption cernogratz 2 9,611 02-15-2017, 11:00 AM
Last Post: Administrator
  Suggestion hodzicemir 1 7,952 09-17-2015, 02:15 PM
Last Post: Dell_Brett
  Edit problem apocalipse 9 12,243 01-20-2013, 07:50 PM
Last Post: apocalipse
  Some Suggestion mybest 1 5,914 12-26-2011, 05:52 PM
  What is Your Suggestion? Administrator 7 11,626 02-28-2009, 02:50 AM
Last Post: concreteok
