Civil Engineering Association Forum Discussion Suggestion & Complains Archive [Suggestion] Edit "Engineering Problems" desciption
 cernogratz
Newbie
User ID: 1116
Threads: 2
Likes: 13 in 2 posts
Given Likes: 5
Points:360 EP
06-27-2016, 02:10 AM
I have a problem with s-curve and yes it is an engineering problem but the description says "If you have a problem in design or analysis of your structure, put it here and our members will try to give a solution to it."...So it does not include problems encountered in management and construction of project. I suggest we add "management" and/or "construction" to it. Something like this.."If you have a problem in design, analysis, construction and management of your structure/project, put it here and our members and/or admins will try to give a solution to it."
...fall in love with a CIVIL ENGINEER because we build a strong FOUNDATION in a relationship...
[-] The following 4 users Like cernogratz's post:4 users Like cernogratz's post
  • Dell_Brett, oanm2000, mtdingen, andysvision
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,012 in 2,180 posts
Given Likes: 42439
Points:110,998 EP
06-27-2016, 10:03 AM
Good suggestion! Thanks for your contribution!
I think we could be more comprehensive, and create such a topic which:
"Other problems related to civil engineering and construction"
Let's see if have enough considerations to implement it!
Dell
[-] The following 6 users Like Dell_Brett's post:6 users Like Dell_Brett's post
  • cernogratz, mtdingen, andysvision, oanm2000, lisine, malc
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 277
Likes: 21,143 in 2,346 posts
Given Likes: 4237
Points:549,114 EP
02-15-2017, 11:00 AM
DONE
[-] The following 4 users Like Administrator 's post:4 users Like Administrator 's post
  • oanm2000, lisine, Dell_Brett, malc
  Suggestion hodzicemir 1 5,941 09-17-2015, 02:15 PM
Last Post: Dell_Brett
  [IN PROGRESS] Suggestion: New section in PostGen for Civil Engineering Videos Mohammad6299 1 19,015 07-10-2015, 09:13 AM
Last Post: Administrator
  【Suggestion】 Edit Time Limit netsonicyxf 1 5,070 02-20-2013, 09:18 AM
Last Post: LiviuM
  Edit problem apocalipse 9 10,997 01-20-2013, 07:50 PM
Last Post: apocalipse
  Some Suggestion mybest 1 5,217 12-26-2011, 05:52 PM
  What is Your Suggestion? Administrator 7 10,330 02-28-2009, 02:50 AM
Last Post: concreteok
