SHAKING-TABLE TEST OF A FRICTION-DAMPED FRAME STRUCTURE
Author: WEN-I LIAO, IMAD MUALLA AND CHIN-HSIUNG LOH | Size: 322 KB | Format: PDF | Quality: Unspecified | Publisher: WEN-I LIAO, IMAD MUALLA AND CHIN-HSIUNG LOH | Year: 2004 | pages: 10
[Image: 25089219017375883038.jpg]
This paper presents results from an international research project devoted to evaluating the seismic performance
of a three-storey steel frame structure equipped with a friction-damping device (FDD) recently developed at the
Technical University of Denmark. Experimental results indicate that the FDD performed very well in reducing
the lateral storey drifts of the test frame. Numerical simulation of the seismic response of the primary and
friction-damped frame was also conducted. This paper also compares the predictions of the displacement demand
from the test results with those obtained by the capacity spectrum method.
a- Follow the Forum Rules.
[-] The following 3 users say Thank You to asim99 for this post:
  • knrsa, ting tsai huang, igor1234
NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 1,849 11-15-2014, 03:07 PM
SEISMIC ASSESSMENT OF AN IRREGULAR THREE-STOREY FULL SCA LE RC TEST STRUCTURE WITH SU TAFATNEB 0 1,060 06-03-2014, 10:11 PM
