Civil Engineering Association eBooks Journals, Papers and Presentations SEISMIC ASSESSMENT OF AN IRREGULAR THREE-STOREY FULL SCA LE RC TEST STRUCTURE WITH SU
Likes: 9,403 in 1,160 posts
Given Likes: 2851
Points:118,565 EP
06-03-2014, 09:11 PM
SEISMIC ASSESSMENT OF AN IRREGULAR THREE-STOREY FULL SCA LE RC TEST STRUCTURE WITH SUBSTANDARD DETAILS
Author: S. J. PARDALOPOULOS Civil Engineer, (AUTh), MSc (DUTh), Greece [email protected] GEORGIA E. THERMOU PhD Candidate, Department of Civil Engineering Demokritus University of Thrace, Greece, STAVROULA J. PANTAZOPOULOU | Size: 737 KB | Format: PDF | Quality: Unspecified | pages: 17
[Image: 46918831032152428541.jpg]
ABSTRACT
Seismic assessment of a full scale 3-storey, irregular reinforced concrete structure that was tested in the European Laboratory for Structural Assessment (ELSA) is presented in the paper. The structure is representative of older design and construction practices in Southern Europe, prior to the introduction of capacity design principles or modern detailing. Parametric analyses where carried out to quantify the effect of plan
eccentricity with the various mechanisms of resistance throughout the frame system, using the same ground motion records and PGA that were used in the actual tests. Mechanisms considered are member effective stiffness, member flexure, member shear, development capacity of anchorages and lap splices, and joint shear. Response parameters considered are the time-histories of the trajectories of the Center of Mass in the three floors, interstorey drift and floor twist. Also calculated are the time histories of demand/supply ratios, λi, for the various mechanisms of resistance.
  • malc, vardan, blaze, zrilek, Clouseau
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 9,854 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 3,320 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 6,205 02-10-2016, 02:49 PM
  Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 4,296 07-19-2015, 07:24 AM
Last Post: Wolverine883
  SEISMIC VULNERABILITY ASSESSMENT USING AMBIENT VIBRATIONS: METHOD AND VALIDATION TAFATNEB 0 3,491 08-12-2014, 09:15 AM
  Specialist Meeting on the Seismic Probabilistic Safety Assessment of Nuclear Faciliti TAFATNEB 0 3,116 08-10-2014, 01:26 PM
  EXPERIMENTAL MULTI-LEVEL SEISMIC PERFORMANCE ASSESSMENT OF 3D RC FRAME DESIGNED FOR D TAFATNEB 0 2,945 06-03-2014, 09:01 PM
