Civil Engineering Association eBooks Journals, Papers and Presentations Evaluation of Discharge capacity of prefabricated vertical drain
Points:66,329 EP
09-25-2012, 11:48 AM
Author: Chua Kang Tor & Jimmy Lee Shen Sun | Size: 450 KB | Format: PDF | Quality: Original preprint | pages: 12
[Image: 11757666730890038269.jpg]
Prefabricated vertical drains are widely used in Singapore for land reclamation to accelerate the consolidation process of the clay. There are several key properties that affects the performance of the vertical drain and in which national test standards have been established and adopted for used. However, one key parameter of the vertical drain is the discharge capacity in which the adopted test standard does not really measure the vertical drain performance. This paper highlights some of the performance parameters of the vertical drain used in Hong Kong and Singapore. At the same time it also highlights the various methods used in Singapore that attempts to measure the discharge capacity of the vertical drain. It also discusses some of the factors that will affect the discharge capacity results.
[-] The following 7 users Like shadabg's post:7 users Like shadabg's post
  • kowheng, Evandrojr, cace-01, avscorreia, utan, malc, Dell_Brett
 tomcat007
User ID: 13907
Threads: 37
Likes: 12 in 5 posts
Given Likes: 59
Points:942 EP
04-19-2017, 03:38 AM
All,
Can someone repost this paper?
  Design curves for Prefabricated Vertical Drains shadabg 1 4,622 04-19-2017, 03:40 AM
Last Post: tomcat007
  Hot-dip-zinc-coating of prefabricated structural steel components ir_71 1 4,303 05-04-2013, 08:25 AM
Last Post: amadoo02
  Marine Prefabricated Vertical Drains for the Craney Island Eastward Expansion jacs127 0 3,121 02-09-2013, 05:20 PM
Last Post: jacs127
  Prefabricated Vertical Drains for Enhanced In Situ Remediation shadabg 0 3,384 09-25-2012, 09:47 AM
Last Post: shadabg
  EVALUATION OF BEARING CAPACITY OF PILES FROM CONE PENETRATION TEST DATA shadabg 0 3,639 09-18-2012, 06:32 AM
Last Post: shadabg
  Seismic capacity evaluation of post-tensioned concrete cve_jule 2 5,878 12-28-2009, 04:28 PM
