Civil Engineering Association eBooks Journals, Papers and Presentations Design curves for Prefabricated Vertical Drains
Points:66,329 EP
09-25-2012, 09:19 AM
Author: Albert T Yeung | Size: 580 KB | Format: PDF | Quality: Scanner | Publisher: Journal of Getotechnical and Geoenvironmental Engineering | Year: 1997 | pages: 5
[Image: 17910368248898779054.jpg]
Vertical drains and preloading are very effective and economical ground modification techniques for accelerating primary consolidation and compensating some secondary compression of soft compressible soils. If vertical sand drains are used, they can be installed at different diameters. The drain diameter required thus becomes a dependent variable in the design process and the drain spacing is determined a priori. The required parameters can be obtained after a few iterations. However, the number of iterations may increase significantly when prefabricated vertical drains or strip drains are used as the drain size is predetermined by manufacturers and available only in a very limited range. Design curves are developed for prefabricated vertical drains in this paper. The equivalent drain diameter is used as the independent variable and drain spacing becomes the dependent variable. Soil smear around the drain is considered but well resistance of the drain is neglected. The curves can be used to design a vertical drain system without unnecessary iterations and/or interpolations when the equivalent drain diameter, degree of consolidation required, time available, and pertinent geotechnical engineering properties of the soil to be consolidated are given.
[-] The following 7 users Like shadabg's post:7 users Like shadabg's post
  • kowheng, Evandrojr, cace-01, avscorreia, malc, Jackass, Dell_Brett
 tomcat007
User ID: 13907
Threads: 37
Likes: 12 in 5 posts
Given Likes: 59
Points:942 EP
04-19-2017, 03:40 AM
All,
Can someone repost this paper? All links are dead
  Forces in Plastic Vertical Drains during installation shadabg 1 4,199 04-19-2017, 03:43 AM
Last Post: tomcat007
  Evaluation of Discharge capacity of prefabricated vertical drain shadabg 1 4,908 04-19-2017, 03:38 AM
  Hot-dip-zinc-coating of prefabricated structural steel components ir_71 1 4,303 05-04-2013, 08:25 AM
Last Post: amadoo02
  Marine Prefabricated Vertical Drains for the Craney Island Eastward Expansion jacs127 0 3,121 02-09-2013, 05:20 PM
Last Post: jacs127
  Prefabricated Vertical Drains for Enhanced In Situ Remediation shadabg 0 3,384 09-25-2012, 09:47 AM
Last Post: shadabg
  Design of Vertical Breakwaters ir_71 0 3,480 10-22-2011, 08:34 AM
