Civil Engineering Association eBooks Journals, Papers and Presentations Seismic capacity evaluation of post-tensioned concrete
 cve_jule
Macedonia
User ID: 6973
Threads: 32
Likes: 888 in 90 posts
Given Likes: 882
12-28-2009, 02:38 PM
[Image: 23168359320449339529.jpg]
Seismic capacity evaluation of post-tensioned concrete slab-column frame buildings designed only
for gravity loads and wind load is presented. The series of nonlinear pushover analyses are carried out
by using the computer program SAP2000. An equivalent frame model with explicit transverse torsional
members is introduced for modeling slab-column connections. The analyses are carried out by following
guidelines in ATC-40 and FEMA-273/274, where several important factors such as P-Delta effects, strength
and stiffness contributions from masonry infill walls, and foundation flexibility are well taken into account.
The pushover analysis results, presented in the form of capacity curves, are compared with the seismic
demand from the expected earthquake ground motion for Bangkok and then the seismic performance can
be evaluated. Numerical examples are performed on the 9- and 30-storey post-tension flat-plate buildings
in Bangkok. The results show that in general post-tensioned concrete slab-column frame buildings without
shear wall possess relatively low lateral stiffness, low lateral strength capacity, and poor inelastic response
characteristics. The evaluation also shows that the slab-column frame combined with the shear wall system
and drop panel can increase the strength and stiffness significantly.
[Image: 79412473308485775869.jpg]
Admin, I hope it is in the right section. Regards.
[-] The following 4 users Like cve_jule's post:4 users Like cve_jule's post
  • kowheng, henrycv, zrilek, sodapas
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
12-28-2009, 03:57 PM
Please upload to any other place.
12-28-2009, 04:28 PM
Let's try this link:
[-] The following 9 users Like kowheng's post:9 users Like kowheng's post
  • aslam, zrilek, baikur, pezhmankhan, ruaumoko, civilphongvan, trantoanxd, jf28, SCREAM7890
  Cause of Cracking in Post-Tensioned Concrete Box Girder Bridges and Retrofit Proced. Aviator 2 7,610 11-18-2020, 04:13 AM
Last Post: tomtumx
  Enhancing the Capacity of Concrete Bridges ir_71 2 7,113 02-14-2018, 10:58 PM
  Evaluation of Discharge capacity of prefabricated vertical drain shadabg 1 5,804 04-19-2017, 03:38 AM
Last Post: tomcat007
  Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 4,710 03-16-2016, 09:41 AM
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 8,538 02-10-2016, 02:49 PM
  POST-TENSIONED CONCRETE FLOORS IN MULTI-STOREY BUILDINGS ir_71 4 10,081 04-23-2015, 09:15 AM
Last Post: titko
  Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 4,813 09-05-2014, 02:03 PM
