Civil Engineering Association eBooks Journals, Papers and Presentations EVALUATION OF BEARING CAPACITY OF PILES FROM CONE PENETRATION TEST DATA
09-18-2012, 06:32 AM
Author: Hani H. Titi & Murad Y. Abu-Farsakh | Size: 1.05 MB | Format: PDF | Quality: Original preprint | Publisher: Louisiana Department of Transportation and Development, Louisiana Transportation Research Center | Year: 1999 | pages: 115
[Image: 13516360727681176984.jpg]
LTRC Project No. 98-3GT
State Project No. 736-99-0533
This study presents an evaluation of the performance of eight cone penetration test (CPT) methods in predicting the ultimate load carrying capacity of square precast prestressed concrete (PPC) piles driven into Louisiana soils. A search in the DOTD files was conducted to identify pile load test reports with cone penetration soundings adjacent to test piles. Sixty piles were identified, collected, and analyzed. The measured ultimate load carrying capacity for each pile was interpreted from the pile load test using Butler-Hoy method, which is the primary method used by DOTD. The following methods were used to predict the load carrying capacity of the collected piles using the CPT data: Schmertmann, Bustamante and Gianeselli (LCPC/LCP), de Ruiter and Beringen, Tumay and Fakhroo, Price and Wardle, Philipponnat, Aoki and De Alencar, and the penpile method. The ultimate load carrying capacity for each pile was also predicted using the static "-method, which is used by DOTD for pile design and analysis.
Prediction of pile capacity was performed on sixty piles, however, the statistical analyses and evaluation of the prediction methods were conducted based on the results of thirty five friction piles plunged (failed) during the pile load tests. End-bearing piles and piles that did not fail during the load tests were excluded from the statistical analyses.
An evaluation scheme was executed to evaluate the CPT methods based on their ability to predict the measured ultimate pile capacity. Four different criteria were selected to evaluate the ratio of the predicted to measured pile capacities. These criteria are: the best-fit line, the arithmetic mean and standard deviation, the cumulative probability, and the Log Normal distribution. Each criterion was used to rank the prediction methods based on its performance. The final rank of each method was obtained by averaging the ranks of the method from the four criteria. Based on this evaluation, the de Ruiter and Beringen and Bustamante and Gianeselli (LCPC/LCP) methods showed the best performance in predicting the load carrying capacity of square precast prestressed concrete (PPC) piles driven into Louisiana soils. The worst prediction method was the penpile, which is very conservative (underpredicted pile capacities).
[-] The following 10 users Like shadabg's post:10 users Like shadabg's post
  • kowheng, warlord1, malc, Andrew seah, utan, simanta, cace-01, zrilek, uetian19, maijuji
  A Compilation of Cyclic Triaxial Liquefaction Test Data asim99 1 6,326 06-20-2019, 12:35 AM
  Evaluation of Discharge capacity of prefabricated vertical drain shadabg 1 5,773 04-19-2017, 03:38 AM
Last Post: tomcat007
  ASCE-41 and FEMA-351 Evaluation of E-Defense Collapse Test TAFATNEB 0 3,083 04-26-2014, 11:22 AM
  Dynamic Cone Penetration Test (DCPT) for Subgrade Assessment shadabg 0 4,046 09-18-2012, 06:18 AM
Last Post: shadabg
  Two- and three-dimensional bearing-capacity solutions for footings on two-layered cla wafiullah 1 4,497 08-02-2011, 11:55 AM
Last Post: Grunf
  Seismic capacity evaluation of post-tensioned concrete cve_jule 2 6,717 12-28-2009, 04:28 PM
