Civil Engineering Association eBooks Journals, Papers and Presentations ASCE-41 and FEMA-351 Evaluation of E-Defense Collapse Test
Likes: 9,403 in 1,160 posts
Given Likes: 2854
Points:118,565 EP
04-26-2014, 11:22 AM
Author: Bruce F. Maison, a) M.EERI, Kazuhiko Kasai, b) M.EERI, and Gregory Deierlein, c) M.EERI | Size: 1.1 MB | Format: PDF | Quality: Unspecified | Publisher: Earthquake Spectra, Volume 25, No. 4, pages 927–953, November 2009; © 2009, Earthquake Engineering Research Institute | Year: 2009 | pages: 27
[Image: 43060132056316913589.jpg]
A welded steel moment-frame building is used to assess performancebased engineering guidelines. The full-scale four-story building was shaken to collapse on the E-Defense shake table in Japan. The collapse mode was a side-sway mechanism in the first story, which occurred in spite of a strongcolumn and weak-beam design. Computer analyses were conducted to simulate the building response during the experiment. The building was then evaluated using the Seismic Rehabilitation of Existing Buildings (ASCE-41) and Seismic Evaluation and Upgrade Criteria for Existing Welded Steel Moment-Frame Buildings (FEMA-351) for the collapse prevention performance level via linear and nonlinear procedures. The guidelines had mixed results regarding the characterization of collapse, and no single approach was superior. They mostly erred on the safe side by predicting collapse at shaking intensities less than that in the experiment. Recommendations are made for guideline improvements.
  • zrilek, ting tsai huang, blaze, vardan, malc, ykhackhack, duazo2009, LiviuM, draluka, faros3000, febo927
  ASTM - Apparatus and Procedure for an In Situ Collapse Test mybest 0 2,787 06-18-2013, 02:58 PM
Last Post: mybest
  Evaluation of progressive collapse potential of multi-story moment resisting steel fr asim99 0 3,477 05-20-2013, 04:58 AM
Last Post: asim99
  EVALUATION OF BEARING CAPACITY OF PILES FROM CONE PENETRATION TEST DATA shadabg 0 3,695 09-18-2012, 06:32 AM
Last Post: shadabg
