Civil Engineering Association eBooks Journals, Papers and Presentations Influence of Axial Stress on Shear Response of Reinforced Concrete Elements
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
05-25-2012, 02:28 AM
Author: Liping Xie, Evan C. Bentz, and Michael P. Collins | Size: 1 MB | Format: PDF | Quality: Unspecified | Publisher: Structural Journal | Year: November 1, 2011 | pages: 10 | ISBN: Volume:108, Issue:6
[Image: 42146796826182460216.jpg]
Abstract:
There is strong disagreement between different code provisions as to the influence of axial stress on shear strength. To examine this influence, six nominally identical reinforced concrete elements representing web regions of girders or walls were loaded under different ratios of longitudinal axial stress to shear stress. The results demonstrated that the application of the basic ACI 318-08 shear approach can significantly overestimate both the beneficial effect of compression on shear and the detrimental effect of tension on shear strength. The ACI 318-08 simple expression for the benefits of compression gave excellent predictions, whereas the simple expression for tension was very conservative. The CSA A23.3-04 shear provisions based on the modified compression field theory (MCFT) provided the best code-based estimates of the shear strength. The full MCFT provided not only the best estimates of conditions at failure—including failure shear stresses and failure crack angles for the full range of axial stresses—but also provided predictions of the complete load-deformation response of the elements. For the two highest compression-to-shear ratios, these load-deformation predictions were reasonable, whereas for the other axial load levels, they were excellent.
Keywords: axial stress; compression; cracking; interaction; shear; tension
[-] The following 8 users Like miquan's post:8 users Like miquan's post
  • malc, Jackass, zrilek, kowheng, st77bel, Dell_Brett, tomtumx, keopisey
  Phd thesis: Chemical Prestressing of Thin Concrete Elements with Carbon Textile Rei poolmand 0 4,062 11-22-2021, 05:12 AM
  Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 4,710 03-16-2016, 09:41 AM
  Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concre yakwetu 1 6,833 07-08-2015, 08:02 AM
Last Post: PinkPant
  A NEW MODEL FOR JOINT SHEAR FAILURE OF REINFORCED CONCRETE INTERIOR BEAM-TO-COLUMN JO TAFATNEB 0 3,741 06-01-2014, 03:35 PM
  DYNAMIC RESPONSE OF HIGH RISE STRUCTURES UNDER THE INFLUENCE OF DISCRETE STAGGERED SH TAFATNEB 0 4,207 05-30-2014, 01:55 PM
  INFLUENCE OF THE STORY STIFFNESS OF REINFORCED CONCRETE FRAME WITH PROPORTIONAL HYSTE TAFATNEB 0 3,414 04-26-2014, 05:57 PM
  SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 4,428 04-03-2014, 12:26 PM
