Civil Engineering Association eBooks Journals, Papers and Presentations INFLUENCE OF THE STORY STIFFNESS OF REINFORCED CONCRETE FRAME WITH PROPORTIONAL HYSTE
Likes: 9,403 in 1,160 posts
Given Likes: 2854
Points:118,565 EP
04-26-2014, 05:57 PM (This post was last modified: 04-26-2014, 06:05 PM by TAFATNEB.)
INFLUENCE OF THE STORY STIFFNESS OF REINFORCED CONCRETE FRAME WITH PROPORTIONAL HYSTERETIC DAMPERS ON THE SEISMIC RESPONSE
Author: Juan andrés OviedO* | Size: 2.9 MB | Format: PDF | Quality: Unspecified | Publisher: Revista EIA, ISSN 1794-1237 Número 17, p. 121-137. Julio 2012 Escuela de Ingeniería de Antioquia, Medellín (Colombia) | Year: 2012 | pages: 17
[Image: 40058250181964957737.jpg]
This paper investigates the influence of the story stiffness of reinforced concrete (R/C) frame on the seismic
response of R/C buildings with proportional hysteretic dampers. For this purpose, non-linear time-history analyses
were conducted on a series of multi-degree-of-freedom system models that include a wide range of structural
parameters and vertical distributions of story stiffnesses and strengths of R/C main frame and dampers. Although
the basic purpose of damper installation is to reduce deformation demands, the results of analyses indicate that
the story-drift demand on an entire system could be larger than that of the structure without dampers, depending
highly on the stiffness and response period of R/C main frame. Moreover, dampers are shown to be more efficient
in reducing the story-drift demand when installed into a flexible R/C main frame.
SEISMIC PERFORMANCE OF STORY-DRIFT-CONTROLLED REINFORCED CONCRETE FRAMES WITH HYSTERETIC DAMPERS
Author: Juan Andres OVIEDO-AMEZQUITA Candidate for the Degree of Doctor of Engineering Supervisor: Professor Mitsumasa MIDORIKAWA Division of Architectural and Structural Design | Size: 327 KB | Format: PDF | Quality: Unspecified | pages: 6
In the passive control of building structures, hysteretic
dampers are the most prevalent structural members
installed into a building to improve its seismic
performance through dissipating most of the vibration
energy imposed by ground motions.
  • vardan, rezart, malc, blaze, zrilek
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 4,497 11-15-2014, 02:07 PM
  Seismic performance of concrete frame structures reinforced with superelastic shape TAFATNEB 0 4,418 09-05-2014, 01:59 PM
  Influence of foundation stiffness on vibrations of rotor systems TAFATNEB 0 2,865 08-11-2014, 10:54 AM
  Performance-Based Seismic Retrofit Strategy for Existing Reinforced Concrete Frame Sy TAFATNEB 0 3,202 04-03-2014, 12:41 PM
  SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 3,375 04-03-2014, 12:26 PM
  HOW HAVE CHANGES IN BUILDING CODE PROVISIONS FOR REINFORCED CONCRETE FRAME STRUCTURES TAFATNEB 0 4,219 11-23-2013, 11:45 PM
  Influence of Nonlinear SSI on the Seismic Response of Reinforced Concrete Multistory TAFATNEB 0 3,513 11-23-2013, 02:39 PM
