Civil Engineering Association eBooks Journals, Papers and Presentations [ASCE] Methods of Calculating Wind Loads on Long‐Span Girder Bridges with Tall Piers
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
11-27-2011, 07:40 AM
Methods of Calculating Wind Loads on Long‐Span Girder Bridges with Tall Piers and Comparison
Author: Yiqiang Xiang and Zhengwei Ye | Size: 410 KB | Format: PDF | Publisher: ASCE | Year: 2011 | pages: 22
Calculating wind resistance is one important process in the design of highway bridges. The current codes of many countries include different rules and formulas regarding the calculation of wind resistance. In this paper, the transverse‐direction wind loads on long‐span girder bridges with tall piers were calculated using six codes from different countries under various terrain, pier height, and girder length conditions. The pier‐bottom shear force and moment results of transverse wind loads calculated using these six codes were compared to those obtained using the buffeting frequency domain method. Results showed that, in class B terrain, wind load results predicated by China's 2004 general codes for the design of highway bridges and culverts, China's 2004 wind‐resistant design specifications for highway bridges, Japan's 2007 wind resistant design manual for highway bridges, and part two of Britain's 2006 steel, concrete, and composite bridge specifications for loads resembled each other closely. Some difference was found to exist among class A, C, and D terrain. The 2007 AASHTO LRFD bridge design specifications and China's 2001 load codes for the design of building structures showed significant differences from the other four codes on all kinds of terrain. The applicability of the wind load rules in the AASHTO LRFD bridge design specifications to long‐span girder bridges with tall piers merits further discussion. China's wind load calculations of load code for the design of building structures mainly depended on the experience parameters of architectural structures with large dimensions, and had limited applicability to bridge structures. For long‐span girder bridges with tall piers, such as bridges with span length to width or depth ratios exceeding 30 or pier height to transverse width ratio exceeding 10.7, the wind load calculated using these codes was generally underestimated due to the neglect of the effects of aeroelastic forces, which must be taken into account in the design of these kinds of bridges.
[-] The following 11 users Like mybest's post:11 users Like mybest's post
  • kowheng, Jackass, blaze, batata666, malc, zrilek, henrycv, slowet, marion33, tluc, ting tsai huang
  Cause of Cracking in Post-Tensioned Concrete Box Girder Bridges and Retrofit Proced. Aviator 2 7,802 11-18-2020, 04:13 AM
Last Post: tomtumx
  Tall building foundations: design methods and applications RyanRS 0 4,422 01-27-2017, 10:30 AM
Last Post: RyanRS
  Seismic behavior of box girder cable-stayed bridges considering large deformations arshiakh 1 6,037 03-01-2015, 08:09 PM
Last Post: bridgeengineer
  Seismic analysis of a three- span deck girder bridge TAFATNEB 0 3,924 05-03-2014, 09:01 AM
  [ASCE] Buckling Analysis of a Long‐Span Roof Structure Collapsed during Construction mybest 1 5,913 04-08-2014, 11:35 AM
Last Post: Mohammad6299
  Pushover Analysis of Long Span Bridge Bents TAFATNEB 0 4,235 12-12-2013, 08:35 PM
  Influence of diagonal braces in RCC multi-storied frames under wind loads: A case stu TAFATNEB 0 3,962 11-25-2013, 04:36 PM
