Civil Engineering Association Software Software Product Bentley Products Bentley SewerCAD v8i (SELECT series 2) 08.11.02.49 (30 Days Trial)
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,982 in 4,091 posts
Given Likes: 612
01-23-2011, 04:29 PM
(30 Days Trial)
SewerCAD V8i is an extremely powerful program for the design and analysis of gravity flow and pressure flow through pipe networks and pumping stations. The program can be run in Microstation, AutoCAD, and ArcGIS modes, giving you all the power of Microstation and AutoCAD's capabilities, or in Stand-Alone mode utilizing our own graphical interface.
SewerCAD V8i allows you to construct a graphical representation of a pipe network containing information such as pipe data, pump data, loading, and infiltration. You have a choice of conveyance elements including circular pipes, arches, boxes and more.
The gravity network is calculated using the built-in numerical model, which utilizes both the direct step and standard step gradually varied flow methods. Flow calculations are valid for both surcharged and varied flow situations, including hydraulic jumps, backwater, and drawdown curves. You also have the flexibility to mix gravity and pressure components freely, building your systems in parallel or in series as they exist in the field. Pressure elements can be controlled based on system hydraulics, turning pumps on and off due to changes in flows and pressures.
Trial
VIP see in your section how to renew the Bentley Trials.
[Image: 78783908009378251681.gif]
[-] The following 13 users Like BennyP's post:13 users Like BennyP's post
  • usman, Dell_Brett, CVega, gacella, Vanfa, mahyarov, almadar12, oanm2000, Grunf, bigone, sasan7351, nuttapolk, al_sharis
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
12-02-2011, 04:33 AM
Bentley SewerCAD V8i - Cumulative Patch Set for build 08.11.02.49
(Version: 08.11.02.49 Date: 10/17/2011) 1.94 MB)
  • Dell_Brett, Vanfa, priya, al_sharis
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
12-04-2011, 03:45 PM
(Version: 08.11.02.75 Date: 11/7/2011) 251.39 MB
[-] The following 6 users Like BennyP's post:6 users Like BennyP's post
  • Vanfa, mazzam, mahyarov, liamsi, al_sharis, malc
  Portable Bentley RAM Connection V8i (SELECT Series 3) 7.3.1 jamildear4u 4 16,206 09-25-2017, 06:25 PM
Last Post: Aviator
  Bentley WaterGEMS v8i Select series 5(08.11.05.61) emmi 2 10,119 09-28-2015, 08:38 PM
Last Post: joker™
  RAM Elements V8i (SELECTseries 4) 13.0.0.22 1000 days trial BennyP 9 24,079 08-23-2015, 06:24 AM
Last Post: ykhackhack
  RAM Connection V8i (SELECTseries 4) 8.0.0.23 1000 days trial BennyP 12 36,353 08-18-2015, 09:00 AM
  Bentley PondPack 08.11.01.54 V8i (30 days trial and renew) BennyP 4 13,204 02-15-2015, 12:06 AM
Last Post: fayezkazi
  SewerCad 5.6 Unlimited Pipes betinnn 1 7,930 03-25-2014, 07:19 PM
Last Post: mazzam
  Bentley Staad Pro v8 (SELECTseries 4) 20.07.09.31 (15 days trial) BennyP 4 15,234 09-09-2013, 05:23 AM
Last Post: pezhmankhan
