Bentley WaterGEMS v8i Select series 5(08.11.05.61)
[Image: 70810873989547293763.jpg]
[Image: 67545468933672183633.jpg]
WaterGEMS is a multiplatform solution for the analysis of water and sewerage networks. The solution has improved compatibility, means the creation of geospatial modeling, optimization and management of resources. Package WaterGEMS is an easy-to-use environment for engineering analysis, design and optimization of water and sewage systems: analysis of fire protection systems and concentrations of the components prior to calculating the energy consumption and control capital costs.
Supports four platforms: standalone interface Windows , interface ArcGIS (for integration with the data in the format of GIS , thematic mapping and publications) interface MicroStaton (for linking geospatial media planning and engineering design) and interface AutoCAD (for the built-compatibility with the most popular in the world CAD ).
Main options WaterGEMS in part g The hydraulic properties, maintenance and water quality:
◾Simulation of steady states.
◾Simulation longer time intervals.
◾Analysis of the concentrations of the components.
◾Sourcing.
◾Analysis of criticality.
◾Analysis mixing tanks.
◾Analysis of aged water.
◾Analysis of the flow of fire extinguishing systems.
◾Regulation or rule-based logic.
◾Serve with variable speed with the ability to use APEX (Automatic Parameter Estimation extension) .
◾Simulation of sprinkler systems.
◾Simulation leaks.
◾The need for water supply, critical pressure.
◾Unidirectional flushing based on the script.
◾Simulation valves.
[-] The following 9 users say Thank You to emmi for this post:
  • ska51, amindoxiti, oanm2000, warlord1, seriousboy, Albert, 3fan, arspi, smrtnick
[-] The following 3 users say Thank You to Hgoren for this post:
  • PinkPant, nyungaw, GMianG
Dear Hgoren,
I thank you for the first post of you in this forum. But please in the next time be more accurate. You posted the link without title or description for the software and in the fact in the wrong thread.
You shared (BentleySewerGEMS) link in (Bentley WaterGEMS) Thread, your post should post in this topic:
Quote:All links are dead and for old version in the above link
All the best.
Quote:This post will be deleted after 24 hours
No limits to creativity
[-] The following 3 users say Thank You to joker™ for this post:
  • Dell_Brett, emmi, oanm2000
Portable Bentley RAM Connection V8i (SELECT Series 3) 7.3.1 jamildear4u 4 9,366 09-25-2017, 07:25 PM
Last Post: Aviator
Bentley WaterCAD & WaterGEMS V8i SS6 08.11.06.58 er.shyams 1 2,628 02-22-2016, 08:08 PM
Last Post: cvidalv
Bentley WaterGEMS V8i (SELECtseries) 4 08.11.04.50 BennyP 1 2,377 11-21-2013, 10:40 AM
Last Post: jonny78
Bentley WaterGEMS V8i (SELECT series 2) 08.11.02.31 BennyP 6 6,720 01-24-2013, 08:24 AM
Last Post: joker™
RM Bridge (Select Series 3) v08.10.07.02 joker™ 2 6,110 12-23-2012, 05:28 AM
