Civil Engineering Association eBooks Journals, Papers and Presentations FRESH AND HARDENED PROPERTIES OF SELF-CONSOLIDATING FIBER REINFORCED CONCRETE
12-01-2010, 07:50 PM
Author: Hemant B. Dhonde, Y.L. Mo, Thomas T.C. Hsu and John Vogel | Size: 7.8 MB | Format: PDF | Publisher: ACI MATERIALS JOURNAL | Year: 2007 | pages: 40
[Image: 57648780430885727244.jpg]
When steel fibers are added to concrete mix, the tensile and shear resistance of the
traditional fiber reinforced concrete are known to be enhanced. However, fibers are also known
to impede workability of plain concrete. To improve the workability, Self-Consolidating Fiber
Reinforced Concrete (SCFRC) mixes were developed in this study for application in prestressed
concrete beams. Extensive fresh and hardened properties of traditional fiber reinforced concrete
and SCFRC mixes produced using two different types and variable amounts of hooked steel
fibers are presented in this paper. The SCFRC mixes demonstrated satisfactory workability and
stability up to a fiber-factor of 55. In general, SCFRC mixes proved to have greater normalized
tensile strength than the traditional fibrous concrete mixes for the same fiber-factor. The
optimum fiber content was found to be governed by workability requirements of the concrete
mix.
Keywords: steel fiber reinforced concrete, self-consolidating concrete, self-consolidating fiber
reinforced concrete, fresh properties, workability, hardened properties.
  • blaze, Clouseau, usman, Dell_Brett, kowheng, cappotchi, roaming79, theanhpe, adshrt, sodapas, pumapol
  BEHAVIOR OF FIBER-REINFORCED POLYMER (FRP) COMPOSITE PILES UNDER VERTICAL LOADS ir_71 1 6,645 06-01-2015, 05:11 PM
  SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 4,563 04-03-2014, 12:26 PM
  Effects of plastic hinge properties in nonlinear analysis of reinforced concrete buil TAFATNEB 0 4,120 11-23-2013, 12:05 AM
  Use Of Steel Fiber Reinforced Concrete In Structural Members With Highly Complex Stre aslam 1 4,935 04-08-2013, 08:00 AM
  Self Compacting Hybrid Fiber Reinforced Concrete Composites for Bridge Columns kowheng 0 4,402 05-27-2012, 04:46 AM
  Mechanics of Fiber Reinforced Bearings kowheng 0 3,576 05-27-2012, 04:28 AM
  [ASCE] Properties of Asphalt Concrete Layer Interfaces terrorruban 0 3,515 03-09-2012, 01:32 PM
Last Post: terrorruban
