Civil Engineering Association eBooks Journals, Papers and Presentations Self Compacting Hybrid Fiber Reinforced Concrete Composites for Bridge Columns
05-27-2012, 04:46 AM
Author: Kumar, Pardeep; Jen, Gabriel; Trono, William; Panagiotou, Marios; Ostertag, Claudia P. | Size: 4.67 MB | Format: PDF | Publisher: Pacific Earthquake Engineering Research (PEER) Center, University of California, Berkeley | Year: 2011-09 | pages: 138
[Image: 17220553704459394845.jpg]
Self compacting hybrid fiber reinforced concrete composites for bridge columns
PEER-2011/106, Pacific Earthquake Engineering Research (PEER) Center, University of California, Berkeley, authors retain copyright, 2011-09, PDF (4.5 MB) (400/P33/2011-106)
The study developed a self-compacting hybrid fiber reinforced concrete (SC-HyFRC) composite. Optimized specifically for bridge columns, this composite flows under its own weight, completely filling the formwork and achieving full compaction without internal or external vibration. In addition, this SC-HyFRC provides enhanced ductility, shear resistance, and damage tolerance compared to conventional fiber-reinforced composites. To investigate the seismic performance and post-earthquake damage resistance of bridge columns composed of SC-HyFRC, two 1:4.5 scale column specimens were built and tested statically under uni-directional cyclic loading. In both specimens the volumetric transverse reinforcement was 0.37%, which is two to three times less than that of typical Caltrans bridge columns. Both specimens attained large drift ratios of up to 11% without losing axial load carrying capacity and were successful in resisting damage due to spalling of concrete up to drift ratios of 3.6%. Compared to a conventional reinforced concrete column of same dimensions, longitudinal steel ratio, and axial load ratio, the SC-HyFRC columns exhibited superior damage resistance and better load carrying capacity despite a 50% reduction in transverse reinforcement.
PDF|RAR 4.67|4.18 MB
[-] The following 6 users Like kowheng's post:6 users Like kowheng's post
  • Jackass, malc, cace-01, zrilek, blaze, Dell_Brett
  Best Practice Guidance for Hybrid Concrete Construction ir_71 1 6,097 08-17-2018, 09:52 PM
Last Post: gulilero
  BEHAVIOR OF FIBER-REINFORCED POLYMER (FRP) COMPOSITE PILES UNDER VERTICAL LOADS ir_71 1 6,634 06-01-2015, 05:11 PM
  Cement and Concrete Composites journal bridgeengineer 0 4,805 02-02-2015, 06:03 PM
Last Post: bridgeengineer
  DESIGN OF REINFORCED CONCRETE COLUMNS (EUROCODE 2) odiclas 0 4,477 08-26-2014, 03:02 AM
Last Post: odiclas
  SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 4,558 04-03-2014, 12:26 PM
  III - 1 FINITE ELEMENT ANALYSIS OF CONFINED CONCRETE COLUMNS TAFATNEB 0 3,988 03-31-2014, 10:11 PM
  PEFORMANCE OF EXISTING REINFORCED CONCRETE COLUMNS UNDER BIDIRECTIONAL SHEAR AND AXIA TAFATNEB 0 3,970 08-27-2013, 08:45 AM
