Mechanics of Fiber Reinforced Bearings
Author: Kelly, James M.; Calabrese, Andrea | Size: 2.17 MB | Format: PDF | Quality: Unspecified | Publisher: Pacific Earthquake Engineering Research (PEER) Center, University of California, Berkeley, Authors retain copyright | Year: 2012-02 | pages: 110
[Image: 10815332272227640909.jpg]
Mechanics of fiber reinforced bearings
PEER-2012/101, Pacific Earthquake Engineering Research (PEER) Center, University of California, Berkeley, Authors retain copyright, 2012-02, PDF (400/P33/2012-101)
The report contains the findings of a study on the mechanical behavior of unbonded fiber-reinforcedbearings (FRB). Typical FRBs consist of several layers of rubber that are bonded to fiber reinforcing sheets. The purpose of the reinforcement is to prevent the rubber from bulging laterally under compressive load. The most important aspects of these bearings are (i) they do not have thick end plates; (ii) they are not bonded to the top and bottom support surfaces; and (iii) their reinforcements are very flexible. These aspects may seem to be design deficiencies, but they have the advantage of eliminating the presence of tensile stresses in the bearing by allowing it to roll off the supports when it is sheared. This reduces the typical bonding requirements. The weight and the cost of isolators is reduced by using fiber reinforcing, no end-plates, and no bonding to the support surfaces, offering a low-cost lightweight isolation system for developing countries. This work is the comparison between an approximated linear elastic theory and the outputs of finite element analyses.
[-] The following 7 users say Thank You to kowheng for this post:
  • Jackass, malc, cace-01, igor1234, zrilek, ibg0203, Dell_Brett
BEHAVIOR OF FIBER-REINFORCED POLYMER (FRP) COMPOSITE PILES UNDER VERTICAL LOADS ir_71 1 1,896 06-01-2015, 06:11 PM
SEISMIC RETROFIT OF REINFORCED CONCRETE BRIDGES WITH FIBER REINFORCED POLYMER COMPOSI TAFATNEB 0 1,051 04-03-2014, 01:26 PM
Use Of Steel Fiber Reinforced Concrete In Structural Members With Highly Complex Stre aslam 1 1,696 04-08-2013, 09:00 AM
Self Compacting Hybrid Fiber Reinforced Concrete Composites for Bridge Columns kowheng 0 1,506 05-27-2012, 05:46 AM
Strengthening of Masonry Arches with Fiber-Reinforced Polymer Strips Apache 0 1,204 03-31-2011, 08:24 PM
Last Post: Apache
