Civil Engineering Association eBooks Journals, Papers and Presentations Improving Portland Cement Concrete Mix Consistency and Production Rate through Two-St
11-20-2010, 06:11 AM
Improving Portland Cement Concrete Mix Consistency and Production Rate through Two-Stage Mixing
Author: Tyson D. Rupnow, Vernon R. Schaefer, Kejin Wang, Benjamin L Hermanson | Size: 4.5 MB | Format: PDF | Publisher: National Concrete Pavement Technology Center | Year: 2007 | pages: 98
[Image: 65238947160173272798.jpg]
Abstract:
A two-stage mixing process for concrete involves mixing a slurry of cementitious materials and water, then adding the slurry to coarse and fine aggregate to form concrete. Some research has indicated that this process might facilitate dispersion of cementitious materials and improve cement hydration, the characteristics of the interfacial transition zone (ITZ) between aggregate and paste, and concrete homogeneity. The goal of the study was to find optimal mixing procedures for production of a homogeneous and workable mixture and quality concrete using a two-stage mixing operation. The specific objectives of the study are as follows: (1) To achieve optimal mixing energy and time for a homogeneous cementitious material, (2) To characterize the homogeneity and flow property of the pastes, (3) To investigate effective methods for coating aggregate particles with cement slurry, (4) To study the effect of the two-stage mixing procedure on concrete properties, (5) To obtain the improved production rates. Parameters measured for Phase I included: heat of hydration, maturity, and rheology tests were performed on the fresh paste samples, and compressive strength, degree of hydration, and scanning electron microscope (SEM) imaging tests were conducted on the cured specimens. For Phases II and III tests included slump and air content on fresh concrete and compressive and tensile strengths, rapid air void analysis, and rapid chloride permeability on hardened concrete.
Key Words:
homogeneity—interfacial transition zone—mixing energy—mixing methods— rheological properties—two-stage mixing
  • kowheng, pedzaquino, Dell_Brett, toa011, oanm2000, tpipkpo, fer962933
  The effects of aggregates characteristics on the performance of Portland cement ir_71 2 6,880 03-06-2015, 04:40 AM
Last Post: Veggeta
  Cement and Concrete Composites journal bridgeengineer 0 4,677 02-02-2015, 06:03 PM
Last Post: bridgeengineer
  CONCRETE & CEMENT SLABS aslam 0 4,272 08-19-2012, 02:21 AM
Last Post: aslam
  Influence of Cellulose Ethers on the Kinetics of Early Portland Cement Hydration ir_71 0 3,686 02-24-2012, 06:23 PM
  Portland Cement Pervious Concrete Pavement datagap 0 3,777 05-06-2011, 11:11 AM
Last Post: datagap
  Rubblization of Portland Cement Concrete Pavements ir_71 1 4,916 03-29-2011, 11:54 AM
Last Post: 3fan
  The Use of Limestone in Portland Cement ir_71 0 3,464 03-26-2011, 06:35 AM
