Civil Engineering Association eBooks Journals, Papers and Presentations CONCRETE & CEMENT SLABS
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
Points:42,050 EP
08-19-2012, 02:21 AM (This post was last modified: 08-19-2012, 08:16 AM by Dell_Brett.)
Author: - | Size: 1.2 MB | Format: PDF | Quality: Unspecified | Publisher: - | Year: - | pages: - | ISBN: -
[img][Image: 63152691277258740121.jpg][/img]
Laitance does occur, and tile system failures are far too
common on slabs.
• Always be aware of how the slab was finished prior to
commencing tiling.
• If in doubt, conduct the water and acid tests as detailed in this
presentation.
• Test for the presence of curing or hardening compounds.
• Encourage concreters to employ good concreting practices, and
to finish their slabs with a wood float finish where possible.
• Always use the best possible surface preparation techniques
and primer and adhesive systems to overcome problems in the
slabs surface.
Moderator Note:
After downloading, must add a .PDF extension to the file
[-] The following 10 users Like aslam's post:10 users Like aslam's post
  • malc, joker™, isurya, pedzaquino, cace-01, ykhackhack, Jackass, blaze, zrilek, subin91
  Cement and Concrete Composites journal bridgeengineer 0 4,517 02-02-2015, 06:03 PM
Last Post: bridgeengineer
  Precast concrete floor slabs ir_71 1 5,100 02-04-2014, 06:31 AM
Last Post: Mohammad6299
  A NEW DESIGN METHOD FOR PRESTRESSED CONCRETE CONTINUOUS FLAT SLABS asim99 0 4,176 11-28-2012, 09:45 PM
Last Post: asim99
  Portland Cement Pervious Concrete Pavement datagap 0 3,620 05-06-2011, 11:11 AM
Last Post: datagap
  Rubblization of Portland Cement Concrete Pavements ir_71 1 4,709 03-29-2011, 11:54 AM
Last Post: 3fan
  The flexural rigidity of reinforced concrete slabs melkat 0 3,942 01-19-2011, 11:35 AM
Last Post: melkat
  Strength Measurements Using Maturity for Portland Cement Concrete Pavement Constructi ir_71 0 4,056 11-23-2010, 06:46 AM
