Portland Cement Pervious Concrete Pavement
Current time: 06-19-2018, 11:54 AM
Author: datagap
Last Post: datagap
Replies 0
Views 1472
Portland Cement Pervious Concrete Pavement: Field Performance Investigation on Parking Lot and Roadway Pavements
Author: Norbert Delatte, Dan Miller, Aleksandar Mrkajic | Size: 1.8 MB | Format: PDF | Publisher: RMC Research & Education Foundation, Cleveland State University | Year: 2007 | pages: 79
[Image: 45132529947928342552.png]
Portland Cement Pervious Concrete (PCPC) has an excellent performance history in the Southeastern U.S., but until recently has seen limited use in environments with significant freeze-thaw cycles. Therefore, assessment of actual field performance is important. This project documents field observations, and nondestructive testing results of PCPC sites located in the states of Ohio, Kentucky, Indiana, Colorado, and Pennsylvania. PCPC is most often used as a pavement for parking lots. Field performance depends on the quality of the mixture as well as proper control of construction and curing. In addition to field observations and nondestructive testing, laboratory testing was performed on cores removed from some of the test sites. Generally, the PCPC installations evaluated have performed well in freeze-thaw environments with little maintenance required.
The research goals included developing recommendations as to how to build PCPC pavements in freeze-thaw environments, and how to prevent clogging. Observations suggest that providing sufficient drainage under PCPC pavements to keep them from becoming saturated in freezing weather, as recommended by the NRMCA, is likely to be effective. Site specific observations of clogging patterns provided insight into sources of clogging, and how these may be avoided.
[-] The following 12 users say Thank You to datagap for this post:
  • 3fan, toa011, Dell_Brett, civilteam, blaze, gatob, oanm2000, Jackass, kowheng, parwez007, pram, cepot
The effects of aggregates characteristics on the performance of Portland cement ir_71 2 2,144 03-06-2015, 05:40 AM
Last Post: Veggeta
Cement and Concrete Composites journal bridgeengineer 0 1,432 02-02-2015, 07:03 PM
Last Post: bridgeengineer
CONCRETE & CEMENT SLABS aslam 0 1,262 08-19-2012, 03:21 AM
Last Post: aslam
Influence of Cellulose Ethers on the Kinetics of Early Portland Cement Hydration ir_71 0 1,081 02-24-2012, 07:23 PM
Pervious Concrete Pavements ir_71 0 1,229 04-30-2011, 06:42 AM
