Civil Engineering Association eBooks Journals, Papers and Presentations Pervious Concrete Pavements
Points:178,871 EP
04-30-2011, 05:42 AM
Author: Paul D. Tennis, Michael L. Leming, and David J. Akers | Size: 1 MB | Format: PDF | Publisher: PCA | Year: 2004 | pages: 32 | ISBN: 0893122424
[Image: 13817444609716868862.jpg]
Pervious concrete pavement is a unique and effective means to meet growing environmental demands. By capturing rainwater and allowing it to seep into the ground, pervious concrete is instrumental in recharging groundwater, reducing stormwater runoff, and meeting U.S. Environmental Protection Agency (EPA) stormwater regulations. In fact, the use of pervious concrete is among the Best Management Practices (BMP) recommended by the EPA— and by other agencies and geotechnical engineers across the country—for the management of stormwater runoff on a regional and local basis. This pavement technology creates more efficient land use by eliminating the need for retention ponds, swales, and other stormwater management devices. In doing so, pervious concrete has the ability to lower overall project costs on a first-cost basis. In pervious concrete, carefully controlled amounts of water and cementitious materials are used to create a paste that forms a thick coating around aggregate particles. A pervious concrete mixture contains little or no sand, creating a substantial void content. Using sufficient paste to coat and bind the aggregate particles together creates a system of highly permeable, interconnected voids that drains quickly. Typically, between 15% and 25% voids are achieved in the hardened concrete, and flow rates for water through pervious concrete typically are around 480 in./hr (0.34 cm/s, which is 5 gal/ft2/ min or 200 L /m2/min), although they can be much higher. Both the low mortar content and high porosity also reduce strength compared to conventional concrete mixtures, but sufficient strength for many applications is readily achieved. While pervious concrete can be used for a surprising number of applications, its primary use is in pavement. This report will focus on the pavement applications of the material, which also has been referred to as porous concrete, permeable concrete, no-fines concrete, gap-graded concrete, and enhanced-porosity concrete.
  • kowheng, dbsimon29, Jackass, malc, techno, 3fan, datagap, Dell_Brett, shaqee, oanm2000, tluc, zrilek, toa011, warbeast, cigutierrezg, parwez007
  Dynamic Finite-Element Analysis of Jointed Concrete Pavements TAFATNEB 0 4,667 03-31-2014, 10:46 PM
  Design and Construction of Roller Compacted Concrete Pavements in Quebec ir_71 1 5,934 01-21-2013, 02:44 PM
Last Post: jacs127
  Frost Durability of Roller-Compacted Concrete Pavements ir_71 0 4,472 10-21-2011, 04:08 AM
  Portland Cement Pervious Concrete Pavement datagap 0 3,623 05-06-2011, 11:11 AM
Last Post: datagap
  Rubblization of Portland Cement Concrete Pavements ir_71 1 4,712 03-29-2011, 11:54 AM
Last Post: 3fan
  Guidelines for Dowel Alignment in Concrete Pavements ir_71 0 4,127 02-21-2011, 06:06 AM
  Design of Continuously Reinforced Concrete Pavements Using Glass Fiber Reinforced Pol ir_71 0 3,876 02-03-2011, 05:04 AM
