Civil Engineering Association eBooks Journals, Papers and Presentations Guidelines for Dowel Alignment in Concrete Pavements
02-21-2011, 06:06 AM
Author: Lev Khazanovich, Kyle Hoegh, Mark Snyder | Size: 3.94 MB | Format: PDF | Publisher: TRB | Year: 2009 | pages: 59 | ISBN: 9780309117852
[Image: 73137874095882612138.jpg]
Dowels are used in jointed portland cement concrete (PCC) pavements to provide load transfer, reduce faulting, and improve performance. These dowels are placed either manually before concrete placement or during construction by automatic dowel bar inserters to expedite construction and reduce cost. Inspection of pavements in several states revealed that misalignment of dowels generally occurs regardless of the placement method. These inspections also revealed that slab cracking and other forms of distress may not always occur as a result of such misalignment. However, limited research has been performed to determine the extent of dowel misalignment in pavement construction and its effect on performance. This report presents the research conducted under NCHRP Project 10-69 to address the issues associated with dowel alignment and develop approaches for estimating the effects of different levels and types of misalignment on performance, thus improving the analysis and design of concrete pavements. The objective of this research is to develop guidelines for dowel alignment in concrete pavements. The research addresses all forms and combinations of dowel misalignment (i.e., vertical and lateral skew and displacement).
  • cace-01, kowheng, usman, Dell_Brett, oanm2000, shaqee, Grunf, cigutierrezg, toa011
  NIST: Best Practice Guidelines for Structural Fire Resistance Design of Concrete and ir_71 2 7,438 03-19-2017, 09:43 PM
Last Post: Dell_Brett
  Dynamic Finite-Element Analysis of Jointed Concrete Pavements TAFATNEB 0 4,810 03-31-2014, 10:46 PM
  Design and Construction of Roller Compacted Concrete Pavements in Quebec ir_71 1 6,078 01-21-2013, 02:44 PM
Last Post: jacs127
  Frost Durability of Roller-Compacted Concrete Pavements ir_71 0 4,588 10-21-2011, 04:08 AM
  Pervious Concrete Pavements ir_71 0 4,161 04-30-2011, 05:42 AM
  Rubblization of Portland Cement Concrete Pavements ir_71 1 4,888 03-29-2011, 11:54 AM
Last Post: 3fan
  Design of Continuously Reinforced Concrete Pavements Using Glass Fiber Reinforced Pol ir_71 0 4,006 02-03-2011, 05:04 AM
