Civil Engineering Association eBooks Journals, Papers and Presentations The Use of Limestone in Portland Cement
03-26-2011, 06:35 AM
Author: Peter Hawkins, Paul Tennis, and Rachel Detwiler | Size: 1.6 MB | Format: PDF | Publisher: PCA | Year: 2003 | pages: 41 | ISBN: 0893122297
[Image: 71708418764619710158.jpg]
Data from published literature and laboratory tests regarding use of limestone in portland cement are reviewed. Emphasis is placed on amounts of 5% or less. The effects of interground and blended limestone on the particle size distribution of cement and workability of mortar and concrete are reported. Hydration behavior is examined with regard to chemistry, heat evolution, microstructure, and setting time. The properties of hardened mortar and concrete made with limestone portland cement are examined and compared to those made with non-limestone portland cements–including compressive and flexural strength, volume stability, durability (permeability, carbonation, freeze/thaw resistance, sulfate and chloride resistance, and alkali-silica reaction), and interactions with mineral and chemical admixtures. Quality control of the limestone, limestone portland cement, and concrete is also discussed. In general, the use of up to 5% limestone does not affect the performance of portland cement. Strengths of cements with limestone can be optimized by grinding to an appropriate particle size distribution. An optimized portland cement containing up to 5% limestone can exhibit improvements in workability as compared to the same cement without limestone. Energy requirements for both pyroprocessing and comminution are reduced by the use of limestone.
  â€˘ kowheng, concreteok, gulilero, blaze, zrilek, isurya, pedzaquino, oanm2000, cigutierrezg, melkat, Umer.Aleem
  The effects of aggregates characteristics on the performance of Portland cement ir_71 2 6,880 03-06-2015, 04:40 AM
Last Post: Veggeta
  Influence of Cellulose Ethers on the Kinetics of Early Portland Cement Hydration ir_71 0 3,687 02-24-2012, 06:23 PM
  Portland Cement Pervious Concrete Pavement datagap 0 3,778 05-06-2011, 11:11 AM
Last Post: datagap
  Rubblization of Portland Cement Concrete Pavements ir_71 1 4,917 03-29-2011, 11:54 AM
Last Post: 3fan
  Solidification and Stabilization of Wastes Using Portland Cement ir_71 0 3,186 03-17-2011, 06:39 PM
  Strength Measurements Using Maturity for Portland Cement Concrete Pavement Constructi ir_71 0 4,234 11-23-2010, 06:46 AM
  Improving Portland Cement Concrete Mix Consistency and Production Rate through Two-St ir_71 0 4,566 11-20-2010, 06:11 AM
