Punching Shear Retrofit Method Using Shear Bolts for Reinforced Concrete Slabs under
Punching Shear Retrofit Method Using Shear Bolts for Reinforced Concrete Slabs under Seismic Loading
[Image: 25073506045482972651.jpg]
The shear bolts are a new type of transverse reinforcement developed for retrofit of existing structures
against punching. This research focuses on how the shear bolts can improve the punching-shear
capacity and ductility of the existing slab-column connections under vertical service and lateral
seismic loads.
A set of nine full-scale reinforced concrete slab-column connection specimens were tested under
vertical service and cyclic loads. The vertical (gravity) load for each specimen was kept at a constant
value throughout the testing. The cyclic lateral drift with increasing intensity was applied to the
columns. The specimens were different in number of bolts, concrete strength, number of openings,
and level of gravity punching load. Strains in flexural rebars in the slabs, crack widths, lateral loads,
and displacements were obtained.
The peak lateral load (moment) and its corresponding drift ratio, connection stiffness, crack width,
and ductility were compared among different specimens. The testing results show that shear bolts can
increase lateral peak load resisting capacity, lateral drift capacity at peak load, and ductility of the
slab-column connections. Shear bolts also change the failure mode of the slab-column connections
and increase the energy dissipation capacity.
The thesis includes also research on the development of guidelines for shear bolt design for concrete
slab retrofitting, including the punching shear design method of concrete slab (with shear bolts),
dimensions of bolts, spacing, and influence of bolt layout patterns. Suggestions are given for
construction
[-] The following 12 users say Thank You to yanburak for this post:
  • kowheng, jcbv, vsa2010, blaze, Grunf, arunsmt, jaks, shaqee, ruaumoko, pssst, Svetoslav, techno
Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 5,780 08-01-2017, 10:19 AM
Last Post: abdulazizk
Cause of Cracking in Post-Tensioned Concrete Box Girder Bridges and Retrofit Proced. Aviator 1 1,372 10-22-2016, 03:30 AM
Last Post: gulilero
Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 1,140 03-16-2016, 10:41 AM
Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concre yakwetu 1 2,246 07-08-2015, 09:02 AM
Last Post: PinkPant
SEISMIC DESIGN FACTORS FOR PRECAST CONCRETE SHEAR WALL PARKING GARAGES TAFATNEB 0 1,941 02-12-2015, 02:39 PM
