Civil Engineering Association eBooks Journals, Papers and Presentations e-Analysis of High-Rise Buildings Subjected to Wind Loads
 ivanveliki
User ID: 1250
Threads: 47
Likes: 886 in 110 posts
Given Likes: 480
04-22-2009, 06:51 PM
JOURNAL OF STRUCTURAL ENGINEERING © ASCE / JULY 2008
Authors
Dae-Kun Kwon; Tracy Kijewski-Correa; and Ahsan Kareem
Abstract: The NatHaz Aerodynamic Loads Database {NALD) "http://aerodata.ce.nd.edu" introduced in 2000 has served an important first step in establishing an on-line experimental archive of high-frequency base balance (HFBB) data for use in the preliminary design of
high-rise buildings subjected to wind loads. As a result, NALD was recently introduced in the Commentary of ASCE 7-05 (C6.5.8) as an alternative means of assessing the dynamic wind load effects on high-rise buildings. This paper presents NALD version 2.0 (v. 2.0), integrating the latest advances in data management and mining for interactive queries of aerodynamic load data and an integrated on-line analysis framework for determining the resulting base moments, displacements, and equivalent static wind loads for survivability and accelerations for serviceability (habitability). The key feature of NALD v. 2.0 is the flexibility its analysis module offers: Users may select not only the data from the on-line NatHaz aerodynamic loads database, but also may input desired power spectral density (PSD) expression or wind tunnel-derived PSD data set obtained from a HFBB experiment for the evaluation of wind load effects on high-rise buildings. Thus, it serves as a stand-alone analysis engine. Examples illustrate the capabilities of NALD v. 2.0 and provide comparisons of response estimates to demonstrate the flexibility of the analysis engine to provide a platform that can be readily expanded and supplemented to yield a comprehensive, simplified, and efficient avenue for e-analysis of high-rise buildings.
[-] The following 12 users Like ivanveliki's post:12 users Like ivanveliki's post
  • Administrator , Administrator , paulocs, paulocs, julioreptil, cve_jule, optima, franck, kowheng, slowet, techno, warbeast
 kvtasp
User ID: 7690
Threads: 69
Likes: 2,028 in 379 posts
Given Likes: 791
01-29-2012, 07:07 AM
[-] The following 6 users Like kvtasp's post:6 users Like kvtasp's post
  • 3fan, kowheng, malc, Jackass, Grunf, lednar_ved
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 8,744 02-10-2016, 02:49 PM
  Fazlur R. Khan - Current Trends in Concrete High-Rise Buildings RyanRS 0 5,167 09-16-2015, 03:41 AM
Last Post: RyanRS
  Design of High-Rise Buildings RyanRS 0 5,511 06-06-2015, 01:32 PM
Last Post: RyanRS
  Strength reduction FEM in stability analysis of soil slopes subjected to transient un PinkPant 0 5,306 06-03-2015, 07:40 AM
Last Post: PinkPant
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 5,991 11-15-2014, 02:07 PM
  Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 5,815 10-21-2014, 08:57 AM
Last Post: Munykong
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 5,841 09-05-2014, 01:46 PM
